2006 lexus rx330 leaked radiator
hey guys.. I'm the second owner of the lexus rx330 06.. recently ..I discovered a leak in the radiator...currently the car had 52k miles...which is out of warranty...will the dealer fix this without charge?..or you out of luck...btw..I found some of the 04-05 got this fix under warranty... If you got any ideas, please let me know because I will have to pay 500 at the local shop to fix this issue....thank guys
I think some of the 06's were included, only way to find out is call your dealer.
Are you a registered owner of the Lexus Owners? Once you are it will indicate if you received an extended warranty on the radiator leak TSB. I received an extended warranty on the radiator issue, dealer noted on my files afterwhich the TSB reminder at the owner's website stopped showig up.
However, please remember that there is a failure location defined on the TSB, not all leaks are covered.
Best bet, call the dealer and give your VIN and describe where the leak is.
I will post VIN's affected on the Radiator TSB tomorrow.
Well I have on 05 and had a radiator leak, it was on the passenger side. I had it fixed under warranty. You might wanna check with your local dealer to see if it'll be covered. I am not sure if it was a TSB or Recall issue.
thank guys....I just registered at lexus driver.com...... they have a recall on the brake booster for my car...however, I can't find anything about radiator...the radiator leak area is very closed to car battery..... If you can post the vin # that affected...that would be great... thank for your help guys
I checked and there is no TSB on the radiator leak. And if there is no mention of an extended warranty on your radiator, I guess your leak might not be qualified. Then again you can always try. Good luck.
