*MERGED THREADS*: Headlight Condensation includes DIY instructions (See Post #19)
#166
^^ Time to seal it up...
#167
mandyfig - Thank you for the very descriptive and informative post regarding removing and sealing the Headlight! My 2008 RX 400h passenger headlight has condensation after a very snowy trip to Colorado. With that said, you mentioned just sealing the top of the housing without taking it completely out. Is it still possible to dry it out without completely removing it?
Thanks for any help!
#168
When the weather is permitting, air is dry and lots of sunshine, your headlamps will dry out. Therefore try sealing the top and just wait and see. I suspect everything will work out. However, if you do not want to dry it out forcefully, just monitor and when it is dried out, seal the top. Then it is a waiting game.
To test if yours are sealed enough, wait for a rainy day, unless you want to take your water hose and blast the front hood and lights, that's a guaranteed way of inducing condensation on a compromised head lamp.
Good luck.
Good luck.
#169
Good luck.
Good luck.
#171
Not sure if anyone posted this yet. I found a class action lawsuit against Lexus regarding this issue.
Click the below link:
http://www.topclassactions.com/lawsu...action-lawsuit
#172
I have quite a bit of moisture in both of my 08 RX400h headlight assemblies. Has anyone else experienced this and if so, have you had any success removing it and keeping it out? During the day it will dry up, but it returns at night. I just received the car from Tx, so I am hoping if I open up the assembly and blow some warm dry air in, I can displace the moist air that is currently in there. Don't know if it will be a long term fix. Is it difficult to get to the bulbs to remove them? I still have tons to learn about this vehicle. Thanks
PS I posted it here as I assume the headlight assemblies are the same for all the second generation RXs.
#173
Moesterle 1st off welcome to CL.
There's a ton of posts regarding this issue. Suggest that you perform the seal now. Document your condensation for later claim use. But no sense in leaving the issue unresolved.
Post a pic or 2 of your ride.
#174
2IS/2RX/4RX
https://www-odi.nhtsa.dot.gov/ivoq/
#175
I will file 1 myself!
#176
Is there a specific complaint already in the database? And if there is one, how do we get there? Or you just have to go through the process?
#178
Finally done with headlight fix
After this exercise, i decided to make a pre-emptive strike on the driver's side headlight assembly. It has had no condensation and no issues. However, thought it best to lay a bead of the clear silicone along the top seam of the housing. Did not remove the housing from the vehicle. With the hood up, the top seam presents itself and it is not difficult to lay a bed of clear silicone along its length.
Hope this info is of some assistance to someone out there.
djcrx330
Post script: By the way, today I sent an inquiry e-mail to the law offices that brought the class action lawsuit. I'll let you know what, if anything, I get back.
Jlmemt (05-12-24)
#179
I just got finished sealing both headlights, and replacing the driver’s side ballast. Wow! It works!!!
So, now we play the waiting game to see if moisture shows back up.
Now is my dilemma. I thought it was odd that the ballast did not have a rubber gasket on the bottom panel where the four screws attach. After I finished putting it all back together, I check the parts diagram, and saw that there should have been a gasket there. Strange, that mine did not, and that happens to be the side that had the water damaged ballast, although it was also the side where the seal up top between the black and clear plastic, almost appeared to be dry-rotted. This lamp also had a lot more moisture in it that the passenger side. With all this being said, does that gasket really do anything? I assume it’s to keep water from splashing up from below into the ballast compartment, but really, what are the odds of that? I am wondering if, maybe it would be better to leave off, as if anything, it will give the lamp some "breathing" room.
Opinions??
Thanks
Opinions??
Thanks
#180
Recently did same job
I am guessing that the gasket was not missing. When I did the job on my rx330, at first, it appeared that there was no gasket at the ballast cover. On closer inspection, however, the gasket was in place in sort of a recess or groove (in the cover) that accomodated the gasket very closely. With a probe, I picked out the gasket and treated it, lightly, with a silicone grease. I then reinserted it into the groove and reassembled.
