View Poll Results: What gas do you put into your 2RX?
Premium
0%
Medium
0%
Regular Unleaded
0%
Voters: 0. You may not vote on this poll
Do you need Premium Gas in the 2RX (merged discussion threads)
Old 05-18-07, 10:54 AM
  #181
TunedRX300
TunedRX300's Avatar
Originally Posted by mandyfig
Great thanks. Now, if I can de-bug where Costco and BJ's get their gas, I will feel better.
Multi-sourced, that is why WSJ listed Chevron, Shell, or BP
BTW, MSDS sometimes disclose what in fuel additives bottle.
This guy compiled the data and here is a useful table. Obviously higher % of PEA stronger the stuff and more corrosive (for the lack of better words) it gets. Most of what in the bottle is kerosene, which is used as a carrier to additives.
Redline SI-1 30-50% PEA I believe
Gumout Large Vehicle Complete Fuel System cleaner 30-40%(Same stuff as regane, just larger bottle!)
Gumout Regane 30-40% PEA
Techron Concentrate(not PROGUARD) No one is really sure what the concentration level of PEA is, some have a theory it is 20-25% but no one knows for sure.
http://theoildrop.server101.com/foru...&Number=767794
Old 05-18-07, 10:59 AM
  #182
mandyfig
mandyfig's Avatar
Linky, not worky....
Old 05-18-07, 11:09 AM
  #183
AM1
AM1's Avatar
even if putting 87 octane isnt good for the car, that wont matter cuz i will be returing the car before any problems arise
Old 05-18-07, 12:31 PM
  #184
mandyfig
mandyfig's Avatar
87 is good, per Toyota.
Old 05-18-07, 12:39 PM
  #185
TunedRX300
TunedRX300's Avatar
Fixed in the revised post.
FYI
PEA stands for polyether amine, just to be clear I could care less about the brand of gas or fuel additive, as long as it delivers the result. If you wish to extract useful information amoung marketing messaging, here is Chevron's take on PEA. Apparently this is the stuff that allow Chevron to make it to the top tier gas list.
http://www.max-boost.co.uk/max-boost...0Additives.htm
Old 05-19-07, 09:21 AM
  #186
mandyfig
mandyfig's Avatar
Great information....should we be using additives? Or just get top tier gas? At least if you add additives...then you have plenty and not wondering.
Old 05-19-07, 01:21 PM
  #187
TunedRX300
TunedRX300's Avatar
Depends on your situation.
For someone with a bad case of carbon buildup, top tier gas can do little since % of additives in gasoline is much lower than a full blown treatment. Windex is a good cleaner, but you will never use it to clean BBQ grills, where the heavy duty oven cleaner works better.
For example, see va3ux's comment in this thread.
http://theoildrop.server101.com/foru...0&fpart=3&vc=1
If you have used top tier gas and no obvious problem, I would run a treatment every 6 months, just in case I caught a bad batch of gasoline.
In my case, Costco 87 octane rated gas with EPA minimum additives with Gumout Regane or Chevron Techron every 3-5K works well.
The goal is to keep vital engine parts clean, since no one can open up your engine to take a look, it takes a little experiement to find what suits you the best.
Old 05-20-07, 04:01 PM
  #188
mandyfig
mandyfig's Avatar
Costco has the Chevron Techron, 4 pack @ $9.50. I will get some.
Old 05-27-07, 04:41 AM
  #189
jmaynard
jmaynard's Avatar
For which vehicle? Maybe for the RX330, but NOT the RX350!
Please, people, when you make statements like this, say what you're referring to!
Old 05-27-07, 02:49 PM
  #190
geko29
Super Moderator
Senior Moderator
geko29's Avatar
So the 3.5L in the RX350 is somehow "special" and requires higher octane fuel than the same exact engine with the same exact compression ratio that makes the same hp/torque numbers in the Camry, Avalon, Sienna or RAV4, and also the Highlander, which has almost the same intake/exhaust track as the RX? Sorry, don't buy it.
FWIW, my RX gets its best fuel economy on midgrade (89). Going to 87 or 91/93 I lose 0.8mpg. It runs just fine on 87 though, which is what Toyota recommends for this engine in every single application save its luxury division. There's nothing special about it just because it has a prettier engine cover on top.
Old 05-27-07, 07:32 PM
  #191
BBHanks
BBHanks's Avatar
There's nothing special about it just because it has a prettier engine cover on top.[/QUOTE]
It is the same engine with a different cover with with a slanted L on it. No matter how you look at it it is still a Toyota..
Old 05-27-07, 11:22 PM
  #192
AM1
AM1's Avatar
dont forget that since its a lexus it has to use premium. maybe it makes lexus owners feel surperior that they have one?
Old 05-28-07, 04:00 AM
  #193
jmaynard
jmaynard's Avatar
The 2007 RX350 manual says that 91 octane is required for optimum engine performance. If 91 is not available, 87 may be used.
To me, that's about as unequivocal as it gets. Lexus says that 87 is only acceptable if 91 cannot be found.
No, I'm not dumb enough to think that my car needs premium fuel because it's a luxury car. If the manual said 87 was fine, I'd be using it, just like I did for 6 years and 114K miles in my RX300. The manual doesn't say that, so I'm following the manufacturer's recommendation.
Old 05-28-07, 04:48 AM
  #194
biff44
biff44's Avatar
It is the same engine with a different cover with with a slanted L on it. No matter how you look at it it is still a Toyota..[/QUOTE]
They could have exactly the same engine, down to the last bolt, and the computer on the Lexus could be programmed differently so you would need the higher octane in the Lexus. There could be a differrent cam shaft. There are a number of factors that could make a difference in engine life on lower octane. So, unless the manual on the Lexus says it is ok, you are playing with fire. There was a horsepower increase in the RX350. That means something was done to it. I am SURE the marketing department wanted the RX350 manual to say REGULAR gas, but the engineers over-road them.
Old 05-28-07, 07:01 AM
  #195
TunedRX300
TunedRX300's Avatar
At the end of the day, it is a personal preference. But Lexus is known to change octane rating on the ES from one year to the next without any change in the powertrain.
I mentioned this in the other octane discussion thread: it is not the ECM programming, but different chassis require slight different intake and exhaust design that causes the slight performance variation.
For example, GS350 and IS350 use the same 2gr-fse engine, same octane rated gas requirement, but slight different intake and exhaust. Result is slightly different peak torque and hq. Official dyno from Lexus japan:
GS350 dyno
IS350 dyno
Quick Reply: Do you need Premium Gas in the 2RX (merged discussion threads)
