Power door problem
Power door problem
On hot (>90 degrees), sunny days the power door on my 2004 RX 330 does not respond properly to the remote. The door unlocks and moves about a half inch, then abruptly reverses and closes. The door seems to work fine except under the weather conditions mentioned above. Anyone else have this problem?
Thanks!!!
Thanks to CK6speed and rxdriver for quick replies to my thread.
How do I find out about whether there are other TSIBs that might be applicable to my RX330?
Also, how do I find my serial number?
Thanks again!
Thanks again!
Search the forum for "TSIB" (Technical Service Information Bulletin). There are lots of threads, particularly for the 2004 RX 330.
Your serial number is the last 7 digits of the VIN number.
Here are some links that will give you an idea of the most common issues.
https://www.clublexus.com/forums/sho...d.php?t=116467
https://www.clublexus.com/forums/sho...d.php?t=169382
https://www.clublexus.com/forums/sho...=109521&page=5
https://www.clublexus.com/forums/sho...d.php?t=154541
https://www.clublexus.com/forums/sho...d.php?t=126711
Originally Posted by rxdriver
That's TSIB # EL002-04, for 2004 RX330's with serial numbers below these:
Japan 2WD: 27908
Japan 4WD: 54350
Canada 2WD: C005492
Canada 4WD: C008100
Japan 2WD: 27908
Japan 4WD: 54350
Canada 2WD: C005492
Canada 4WD: C008100
EL002-04 was released March 30, 2004.
It's for general intermittent malfunction of the power back door. Solution is to replace the ECU for the door. A lot of people complained about the door either not going up or not going down when you hit the button (inside or remote).
The ECU is located in a heck of spot... you need to remove a LOT of the interior trim pieces in the cargo area and left side rear seat to get at the thing. The TSIB says it's only a 1 hour project, but it looks a lot more involved than that. I guess 90% of it is popping off little platsic clips that hold the interior together, so maybe the pros are good at doing that quickly.
