RX330 Transmission
Old 02-17-10, 06:53 PM
  #46
MrBruin09
MrBruin09's Avatar
Originally Posted by lexus114
You should also reset the ecm.
sounds good
Old 02-18-10, 05:35 AM
  #47
xfirechief
xfirechief's Avatar
Rather then add some snake oil why not change all the fliud to get rid of the contaminents? Then put a 100% synthetic oil in?
Old 02-18-10, 09:32 PM
  #48
MrBruin09
MrBruin09's Avatar
Um...maybe you haven't noticed but the Second generation RX seems to have transmission problems. Dealerships can't seem to fix this problem, etc.
If you don't believe in the product that is fine, but don't go around telling me it's snake oil, when it is obviously working for me.
Old 02-19-10, 03:23 PM
  #49
xfirechief
xfirechief's Avatar
So would changing the oil & adding synthetic work & u would not have the dirty contaminated old oil still in the pan.
Tell me after a few 1000 miles or so just how good that "additive" is working, thats all I am trying to say. Clean synthetic tranny fluid will still be like new but the "additive" might be gone.
Old 02-19-10, 03:33 PM
  #50
MrBruin09
MrBruin09's Avatar
I will report back in about 3 months. I did have a transmission flush 12,000 miles ago, and I still had the transmission lag after it. That is the reason I tried this product. I will keep everyone posted.
Old 06-18-10, 05:31 AM
  #51
pjm207
pjm207's Avatar
just checking to see if there was an update on this product. Also, are TSB's free, and how do you know if your used vehicle had them done? Can the dealers tell you by researching the VIN? I checked on the website when I registered the vehicle but there was nothing other than standard services done.
Old 06-18-10, 07:37 AM
  #52
lexus114
lexus114's Avatar
call the dealer that serviced it,and ask if the tsb`s were completed.
Old 10-26-11, 10:15 AM
  #53
Wingnut65
Wingnut65's Avatar
OK, This thread has brought me here. Just had a dealer service manager inform us that the hesitation shift between 35-40 mph on our 2004 RX330 (55,000 miles) is just the nature of the vehicle. He says the car has all the computer updates, but that the hard shift that periodically occurs is normal. It shouldn't be normal in a Lexus!
Now that I have been surfing, I see that this hard shift was a problem when these RX's were brand new as OP tkowalski noted in May '04 regarding his 2004 RX. We got ours used in 2009 with only 24k on it. Now a 2 years later it still has the shift problem that we have had it in the shop 3x for. Now we are told it is normal.
adam8065 , has the Transmatic helped with your problem after 8 months of use?
Old 10-26-11, 10:51 AM
  #54
lexus114
lexus114's Avatar
Do you have a scanner? if you do,clear the ecm. If you dont, disconnect the neg. batt terminal for a while. Then take it out for a drive. Might take care of your problem.
Old 11-19-14, 03:57 PM
  #55
LazarusLng
LazarusLng's Avatar
I am wondering how the additive worked out?? I just bought an 04 330RX. I have yet to reset the computer, and I plan to take it to the dealer for any flash updates that they may have available.
Old 07-01-15, 08:20 AM
  #56
Billion
Billion's Avatar
Originally Posted by tkowalski
I have a 2004 Lexus RX 330 SUV. I've had 2 previous RX 300's. The new RX330 has a computerized transmission. I sometimes experience a slip, hesitation, and sometimes a clunk between 2nd and 3rd gears. It's real obvious. I have not been able to duplicate it at the dealership. It won't happen for a week sometimes and then it will do it 3 or 4 times in one day. One of the techs says it's the nature of the trans. They are not able to give out info if anyone else is experiencing this. Please if someone is experiencing this, let me know. Thanks~ TK Too much money to spend for a car with this concern!!!!
My lexus rx330 2005 model is having this problem now, I do not know what to do, can you tell me what to do?
Old 07-01-15, 02:37 PM
  #57
5W40
5W40's Avatar
My 06 RX330 did same thing at 55~60kph (35~40mph) several times a day as our most local speed limit is 50-60kph, after i did rear differential and transfer case gear oil change two weeks ago, I drive the car for couple days and my daughter as daily driver after that, we both are surprised to find the jerk and surge has gone!
Maybe need more time to prove it, although I think the jerk or surge should tranny related,but at least it works now!
The gear oil I use is Castrol Gear Oil GL-5 80W90 [NOT full synthetic version].
2006 RX330 Transfer Case & Rear Differential Oil Change
Old 03-14-17, 07:18 AM
  #58
RedGemini
RedGemini's Avatar
Sorry to revive an old thread, but I'm assuming the takeaway from this thread is the intermittent "slip" from 2-3 shift is "normal" for this transmission. So, should I just stick to the plan to doing more drain and fills, or should I try to start pushing for a replacement before my warranty expires?
Old 04-07-18, 06:23 AM
  #59
coolioe93
coolioe93's Avatar
Is the additive still working? Any updates?
I bought my RX330 used and it’s been doing this between 2nd and 3rd on light acceleration since I bought it. I paid to have the transmission computer updated and that didn’t fix it. If this is considered normal, then I can live with the annoyance. But if it’s something I need to address before the tranny fails, then I’d like to do that ASAP
any help is appreciated!
Old 04-07-18, 08:12 AM
  #60
Audiqv8
Audiqv8's Avatar
Just a quick question. Is this hesitation shift only occurring on AWD, FWD or both?
Quick Reply: RX330 Transmission
