99 RX300 rear differential help
Hey guys, my 99 RX300 had a bearing fail and I was told that I'm better off buying a used rear diff as the bearing most likely sent shaving inside the diff. I called Lexus to run my vin and was told the car has a limited slip rear diff and that I would need to buy a locking diff. I looked online and could only find non-locking diffs so I called back Lexus and this time the guy I spoke to told me that I have to find a limited slip diff because it's different than a locking and non-locking diff. I ended up calling another Lexus and was told the same "I have a limited slip so I need to buy a locking".
Does anyone know what kind of differential I'm looking for? I'm assuming the differential has to come from a 99-00 only and not an 01-04. Also I've only seen 1 or 2 locking diffs listed but upon calling, they are only empty pumpkins so only non-locking diffs seem to be available.
Any help would be appreciated.
Thanks
Thanks
You have a pretty unique and enviable set-up.
I would go to a local diff specialist and let them do an analysis on the oil and condition of your diff. Replacing the unit is a possibility but most likely it will not be easy or inexpensive. It might be worth overhauling (if needed) the current diff.
Welcome to Club Lexus.
Salim
Salim
Unique and enviable as in a rare option (lsd)?
Ill have check with a local specialist shop to see what they think. It would've have been nice to find a used diff seeing as most were in the $200-$250 range and came with 6-12 month warranties.
Slow_go_400
Performance & Maintenance
04-30-07 10:56 AM
