Power Steering - Lower Return Pipe Leak
Power Steering lower return tube / pipe leaking - on the bracket that holds the pipe. It is the pipe that in on the rail (almost parallel to the engine oil pan). I will post photo later.
I just order the part online (44416-48020) but might deliver in couple days...
Any DIY available of replacing this pipe ? The front bracket/bolt looks like will be difficult to access... Need to remove the front passenger wheel and fender ?
-Mike
(Force to go over a side walk - bang the lower - an now cause power steering lower return tube leak).
RX300 1999 AWD
-Mike
RX300 1999 AWD
