Antifreeze mysteriously disappearing?
Ok guy's, the past 6 months I started noticing the coolant reservoir creeping it's way down to the low mark. I just grabbed some bottled water and added about half of it (16oz bottle) and left it at that, then maybe 4 months ago it was low again!... so I was concerned but not too much, anyways another 2 months go by and it was almost bone dry... I was like what the hell is going on, I was in a hurry so I added a whole 16oz bottled water and closed the hood, now I went out tonight and low and behold it almost back at the low mark again! It has only been drivin about 5 or 6 times in the past 2 months as it's not a daily anymore, I changed the spark plugs a while back when it was consuming the coolant and checked the piston heads and they had a normal amount of carbon on them, none looked out of the ordinary clean, so the head gasket is fine. It's never dripped a drop of water either, and I have not noticed the heater core leaking. I smelled the coolant and it smells normal, no gas odor to it, also there is no odor present inside the vehicle. I'm stumped here, no major issues other than my battery/alternator and a little smell of burning oil from leaky valve cover, any advice/help would be wonderful, and I appreciate anyone that helps! Happy 2016 everyone!
The kit had all kind of adapter but none allowed me to hook on to the radiator. I was able to check the radiator cap.
Assuming there problem is with the radiator, Lexus uses plastic top and overtime they tend to crack open right behind the front edge, which is not visible till the radiator is pulled out.
Salim
I loaned out the testing kit with all adapters from PepBoys and AutoZone, but could not get them to fit on to either the RX, SC or GS.
Salim
Salim
If you want to take advantage of Harbor Freights return policy, they have a kit with an adapter that should work for 89.99 minus the 20%-25% coupons you can find.
I don't think my block is cracked or anything, I've never seen it drip one drop of water, plus it takes a while like over a month for the water level to start dropping. I'm stumped....
Salim
Salim
Mine has a slow leak here. I don't see it on the ground, but occasionally I smell coolant.
I just top it off occasionally.
https://www.clublexus.com/forums/rx-...ml#post8849702
The test fluid will change color immediately if it detects the hydrocarbons.
Check the drivers side of the engine by the thermostat housing...Mine had a crust there and it turned out being a leaking intake manifold gasket to the head. Water actually flows thru the intake on the RX300. After I replaced the gasket (intake) my leakage stopped.
see post number six on this thread for my picture....
https://www.clublexus.com/forums/rx-...side-rear.html
(Oh, I'm sure you know that bottled water is not distilled water - it;'s just filtered which doesn't remove any of the dissolved salts.)
Yea, it's all I had at the time, trust me, it's much safer and cleaner than my water hose.
