Disconnect TPS
Disconnect TPS
I am having a very difficult time disconnecting this connector. Can anyone offer some tips.
It appears to me that i need to press in on the tab, and pull the plug out from the connector.. But so far no go.
I have attached photo of connector.
Let me try this again. I believe the pic in the 1st message is actually of the (already disconnected) IACV connector.
I think this is the one that is giving me fits. Not sure how to remove it.
correct, just press the tab and pull the connector out straight. You can try using a wide flat screwdriver to help it along. Do not pry but use a twisting motion with the screwdriver below the connector while pulling on it with your other hand. Do not use alot of force or you will break the plastic connector.
And smear a small dab of di-electric grease around the connector before you slap it back together. It'll help in controlling moisture as well as making it a lot easier to take apart later.
