Wheel Bearing Replacement, Dealer or Local Shop?
Old 09-07-14, 06:38 AM
fastnoypi
fastnoypi's Avatar
Originally Posted by jnovak01
How long should wheel bearings last? My RX has 140k and I have no wobble or noise yet, but for $200 it may be something I would tackle over a long holiday weekend.
thanks
There is really no average set limit on how long wheel bearings last.
You could do it yourself for less than $200 if you access to a press or have a hub shark/ HF equivalent. http://www.harborfreight.com/fwd-fro...ers-66829.html
Old 09-07-14, 10:23 AM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,102 Likes on 991 Posts
It is not part of preventive maintenance. If you develop a problem then get it fixed.
Salim
Old 09-07-14, 01:44 PM
thomas1
thomas1's Avatar
Have you used one of these? To press the bearing out takes a lot of force, my 12 ton press does it but you wont believe how stressed it is....Otherwise heck I will get rid of the press and use these.
Old 09-08-14, 04:26 AM
fastnoypi
fastnoypi's Avatar
i have, but not on a lexus. I've done it on a subaru and bmw. Others claim you can do it on the car but i opted in both situations to pull the whole knuckle off and put in a vice, and use a breaker bar to get started with the HF kit. If you have a press, the bearing cups in the kits would be handy.
Old 09-08-14, 06:10 AM
thomas1
thomas1's Avatar
Oh I was looking for more floor space by getting rid of the press....Was it hard turn the screw to push bearing out.?
Old 09-08-14, 08:34 AM
fastnoypi
fastnoypi's Avatar
it wasnt hard after i could tell that the bearing cup was centered straight and i started it with the breaker bar and socket. Once i was sure i used my electric impact gun. I think starting it is the tough part since there is rust right up on the edge of the bearing and knuckle. Tolerances are very tight so you have to be dead centered. Well worth the try with the HF kit since their return policy is 30 days. If it works for you, then you could possibly get rid of your press.
Old 09-08-14, 08:35 AM
salimshah
Forum Moderator
salimshah's Avatar
Dont forget that wheel alignment is recommended afterwords.
Salim
jangell
01-07-17 04:45 PM
LS430Lexus
04-29-16 04:38 PM
Benjamin T
Wheels, Tires & Brakes Forum
02-10-07 04:13 PM
lex400sc
12
08-16-02 01:51 AM
Quick Reply: Wheel Bearing Replacement, Dealer or Local Shop?
