Solenoid Problem???
Old 12-20-13, 11:35 AM
skipperben
skipperben's Avatar
Default Solenoid Problem???
having a problem with starting ... two attempts with just a click.. than a partial start.. next attempt .. start right up... I believe its the solenoid... I have no idea where its located... need some advise
Old 12-20-13, 01:27 PM
salimshah
salimshah's Avatar
It is likely the solenoid, but at times if the battery can not produce enough juice you can have the same results. I would urge you to fully charge the battery or try getting a jump. With bad contacts you should get the same click and nothing with a fully charged battery or with a jump.
I looked up the other day and we do not have a DIY on the starter. If you plan to do this, please post a DIY. If you do the contacts, then replace the plunger too. I would advice against cheap after-market stuff. OEM stuff would last you another 10yrs [time is important than milage as the wear is based on the number of starts]
Back to your original question ..
The solenoid is piggy backed on to the starter. Starter for RX is on the driver side, nearly at the top of the engine. Disconnect battery (must), remove engine cover, remove air intake and trace one of the thick wires from the battery and it will take you to the starter. Large coffee mug/fountain-drink size motor.
Salim
Old 12-21-13, 07:28 AM
skipperben
skipperben's Avatar
thanks.. this helps a lot...
Old 12-23-13, 08:31 PM
JAB
JAB's Avatar
Been there done that. Removal and rebuilding of the RX starter is one of the easiest - and financially rewarding - DIYs there is.
Old 02-10-14, 08:12 PM
14GS350F
14GS350F's Avatar
failed starter
Old 02-10-14, 08:35 PM
jimbug
jimbug's Avatar
Probably needs new starter contacts $6 parts and you could replace the plunger for $20 while you're at it. Had to change mine at 74,000 miles and still going at 120,000 miles. Toyota starters are strong, but contacts especially the positive side wear down until they no longer make contact.
mandyfig
07-24-18 10:16 AM
Kalogerus
Performance & Maintenance
14
02-04-12 02:05 PM
guest
03-04-09 07:51 AM
ynvme
06-26-06 08:57 PM
babyGS3
09-02-03 07:37 AM
Quick Reply: Solenoid Problem???
