RX300 Fluids
RX300 Fluids
Probably asked and answered in different posts before but the search function didn't answer my specific questions......
I need to change all of the fluids in my 1999 AWD RX300. Engine oil and transmission fluid, I get. Then I believe the front differential is part of the transmission and shares lubrication with the transmission? Then i gets a little blurry. Is the transfer case separate? What about the rear differential? What is the special "torque sensing LSD fluid" I need and where does that go? I'm not changing the fluids myself but I just want to make sure the independent I'm using knows the ins and outs of the RX300 transmission and drivetrain system.
Thanks,
Thanks,
Partial answer:
The transmission fluid is one fluid (filled through dip-stick), and drains out at two locations ..1) transmission pan 2) front diff-hump (both being lowest points of the system and the full system drain can not happen as fluid is left in the torque converter. What you drain is essentially the sediments. Make sure Toyota type IV (better or equivalent is used and should not be confused with Dexron type IV). It will take you number of drain and fills to get close to 100% fresh. [IMHO not necessary as contamination does not happen].
Rear diff: I have FWD so my information is limited. Only advice I can give is ... the filler plug has a tendency to freeze. So make sure you can budge it before you open the drain plug.
Salim
Salim
The transfer case is separate, and it takes gear fluid.
Also the rear differential is separate, and that too takes gear fluid. As far as the LSD fluid, it depends on whether or not you have the LSD. If you do have the LSD it has a special fluid with friction additives that goes through the same fill hole.
2000, 300, car, check, clublexus, fl, fluid, lexus, list, location, lsd, lubricants, maintenance, powertrain, rx, rx300, transmission
