Is the DRL the high beams (9005)?
Yes they are but configured in series ... need both filament intact and the +12v gets distributed to 6v on each.
Salim
Salim
Does that mean I WILL need a relay fuse for my low beams when installing an HID kit (9006)?
Sorry if i am being annoying ... im still learning a lot about cars, Salim.
Low beam has nothing to do with high beam including drl.
Separate (direct from battery + relay [activated by existing low beam] ) has to do with the current demand of your new (hid) system.
There are plug and play systems too. If you are not sure, ask the manufacturer of the HID kit.
Salim
Salim
