200k Club
200k Club
Sorry guys it's been a while since i visited this site.
Got it used with ~105k or was it 115k?
Changed Trans fluid every 15k with only Toyota T-IV.
Diff fluids are Mobil 1 Syn gear lube every 30k.
Replaced both A/F sensors ~140k. 3rd front brake job and 2nd for the rear since bought.
Replaced both front calipers. Cleaned injectors every 30k as also IAC.
Flex pipe replaced ~120k.
Still running strong, ~19.6 MPG summer/winter. No LEAKS.!!
I am glad to hear reports about those that crossed the 200k threshold.
With 183k on the clock, I am getting close. I have done about the same repair/maintenance items that you have done. But I am on my original o2 sensors! I need to do my door actuators this summer.
Thanks guys.
She still purrs like a kitten. Oil consumption is about 1/2 quart every 5k on Synthetic 5w30.
Forgot about the door lock actuators : Drivers and rear driver side had replacement motors put in.
We all know how much these things are if bought as an assembly new.
Super Moderator
Congratulations on this achievement.
Oddly enough, I celebrate a certain achievement today with my RX300.
Ten years ago today, January 26, 2002 was the day I bought my RX300 at a used car dealer (actually it was a Saturn dealer) in Northern Virginia. One week later, I was in Mexico for over 6 years.
I bought it used in July 2010 It had about 203,000 miles on it.
I change the transmission fluid every 7-8k with only Toyota T-IV.
I recently changed the differential fluid with Royal Purple Synthetic gear lube.
I had new tires, brakes , shocks, and struts put on when I got it in 2010.
The fuel pump went out today after I got the motor oil changed. It's been getting approx. 20.6 MPG.
Got mine in Northern Virginia this past summer used from a private party.
1999 RX300 @ 174k miles.
Now it is at 177k. Planning to drive this baby through my college years. (Freshman at the moment).
Hope to join the 200k soon.
I'll just add a post here for my uncle, as he's not a member of the forum.
99' RX300 AWD ; ~380,000 miles, original engine, original transmission; still run's great, no problems
I bought my 2001 RX300 FWD new in June 2001 and now have 206k. Original transmission. I've recently changed both AF sensors and PCV valve (1st time). Also all new brakes & tires. MPG since new tires has been in the 20.5 - 21.5 range. Sitting on 21mpg at this moment. I've been running premium 93 octane mostly for years and was getting 22.5 & better at times on the old set of tires last summer. Used synthetic 5-30w Mobil or Castrol since 40k, changed every 10k. It is really running like new now with the new brakes & tires. Ahhhh....
