rear lower control arm bushing part#?
Old 08-20-07, 11:03 AM
jimmouse
jimmouse's Avatar
Default rear lower control arm bushing part#?
Any one knows the part# or where to get it? I am just trying to avoid replace the whole arm.
Old 08-20-07, 11:13 AM
Lexmex
Super Moderator
Lexmex's Avatar
jimmouse,
I am not sure from my recollection (after having replaced both arms) that you can get the bushing independently. In fact my uncle and I tried to remove said bushing and it was next to impossible to figure out (couldn't figure out how to get it out).
Old 08-20-07, 11:27 AM
jimmouse
jimmouse's Avatar
I looked over LS and IS, GS, forums. Those guys used some sort of puller. I think it can be done if I can get new bushings. I took off the rear wheel. The bolt and nut are accessible, if not very easily.
Old 08-20-07, 11:49 AM
Lexmex
Super Moderator
Lexmex's Avatar
I also want to try pulling mine out REALLY HARD the next time I have this issue. The manual itself doesn't show that it can be pulled out, and my uncle and I tried to several times.
However, I think Daizen, one of our CL sponsors, had some bushings for the RX300, http://www.daizensporttuning.com/
Old 08-20-07, 12:09 PM
jimmouse
jimmouse's Avatar
They only make bushings for front arms.
Old 08-20-07, 12:13 PM
Lexmex
Super Moderator
Lexmex's Avatar
My uncle told me that they make umpteen kinds of replacement bushings down here and that was what we were going to use should we have been able to get the bushings off.
Old 08-20-07, 01:38 PM
jimmouse
jimmouse's Avatar
That's too bad they do not make it here.
BTW, Lexmex, does your rear control arm set up look like mine? The diagram in the manual looks a little different.
Old 08-20-07, 02:36 PM
Lexmex
Super Moderator
Lexmex's Avatar
Yep, same setup as you had in the other thread. Haven't had a problem with the rear...yet.
Old 08-21-07, 07:15 AM
jimmouse
jimmouse's Avatar
After searching for a few days, I gave up and ordered the whole rod from park place. In case any one need it, the part# is 48730-48050, $99.53.
Old 08-21-07, 07:16 AM
Lexmex
Super Moderator
Lexmex's Avatar
Good to know on this. I promise you next time this occurs, even if I am back in the States, will take a look to see if it can be fixed by means other than trotting out to the dealer and replacing the arm/rod.
Old 08-21-07, 01:01 PM
jimmouse
jimmouse's Avatar
Abo****ely. Those bushings are wear & tear items, and replacable in many other cars. I just do not know why no body makes/sells them.
Old 08-21-07, 05:33 PM
thomas1
thomas1's Avatar
When you are talking control arm do you mean the trailing arm on the rear suspension? I am just interested for trying to follow what you are replacing.
Old 08-23-07, 10:13 AM
jimmouse
jimmouse's Avatar
Still waiting for the part to show up. Hope I can do the work this weekend and shot some pictures for you guys.
Nathamatic
Suspension and Brakes
06-06-15 07:23 PM
breezy4129
IS - 1st Gen (2001-2005)
05-22-14 09:57 AM
stockhatch
14
12-17-10 01:40 PM
GS422"
03-21-09 02:51 AM
itazura
03-07-08 11:40 AM
Quick Reply: rear lower control arm bushing part#?
