I have a bad gas mileage, how about yours ??
#196
Deceleration with no throttle
When ever I drive my wife's 2000 RX300 I always notice that the vehicle tends to decelerate when ever I remove my foot off the throttle. Feels like a small braking force is being applied somewhere. Is this normal?
#197
I feel the very same thing you describe... only I think it the transmission not being warmed up enough to get out of 1st gear... so it revs down.
It feels very much like you are in a descent mode in a fancy SUV on the lowest setting.
Mine is a 1999 rx300. I just had the oil control valve replaced at the dealership. Pray that never happens.
#198
Most if not all of these Lexus models have something built into their ECU's called slope control, which if you are going down a hill the transmission will automatically shift into a lower gear to help slow the car when you touch the brake. Also, when the RX cold, it will not shift out of 2nd gear until it is warmed up. So you are dealing with a couple of scenarios, which is why we would need more information.
Also, this is probably not the right forum to discuss this issue as it is dedicated to poor gas mileage. I should practice what I preach since I already discussed it...
#199
You need to be a little more specific, I mean, the car is supposed to decelerate after you take your foot off the gas pedal, right?
I will explain.
Assuming I am in D gear and moving on a slight downward slope at 40mph and I see traffic ahead slowing down, I will lift my foot off the throttle (no braking). I immediately feel the vehicle slowing down ever so slightly as if a small braking force is being applied. And as OzrkFisher wrote above, it feels like engine braking. This will definitely affect fuel economy since the vehicle is slowed down. Currently averaging 16-17mpg. On my Odyssey when driving same roads it doesn't happen. I could explain it another way using two bicycles: get up to speed then stop peddling and coast; bike one coasts as expected; bike two coasts but slows down quicker as if the brake is rubbing ever so slightly.
Thank you for pointing out 2nd gear limit when cold. I'll pay closer attention but from what I remember, this happens all the time, even when cruising on the highway.
#200
Most likely it's the function of your torque converter, lower gearing on the Lexus and a combination of both. Nothing wrong with your car. It does drag more than the Honda but the clutch take up is also quicker and more efficient that lagging torque converter you have in the odyssey.
#201
Think I found the root of my problem; a clogged PCV valve ( and or combination of dirty IACV / throttle body / VSS). First step was cleaning the IACV (without removing) and throttle body then cleaned the VSS. Car drove better but could still feel the drag. The PCV valve has a spring mechanism at bottom of vertical shaft which was gunked up to the point it no longer functioned. After cleaning and enabling the spring mechanism to function again, I noticed right away how smooth the car accelerated and felt overall. Wasn't until completing the test drive that I noticed the drag was gone as well. Haven't been able to quantify overall gas mileage improvement yet.
EDIT: There were no DTC / CEL / pending codes indicating clogged PCV (as a matter of fact, I haven't seen any codes since my A/F sensors went bad).
#203
Last thing I recommend to do is pull the negative battery cable off for a few mintues to reset the ECU. The short of it is that your driving habits are evaluated so to speak by the ECU and depending on this and the state of the vehicle will ultimately affect your gas mileage.
Another small trick that does the same thing, though not quite as effectively is to pull out (with the key of the ignition) the EFI fuse located here in your fusebox. Take it for at least a minute and then put back in and start up your vehicle. It might have a low idle at first but then should start to pick up. This is normal. Pulling the EFI fuse for a minute can also help reset any CEL (Check Engine Light) you may have, assuming it isn't something that is permantent such as a messed up part, bad sensor, etc, then the light will stay on.
#204
Very helpful thread. I was down to about 15.5 mpg, engine was idling at about 1700rpm. Sure enough the MAF sensor was gunked up. Checked the air filter, it was white as the driven snow ( I think Lexus may have replaced it when they put in the new trans a few weeks back.)
I used the CRC MAF sensor cleaner and let it dry while I unhooked the battery to reset the ECU.
Started the car back up and watched over the next few minutes as the idle dropped steadily down to @800rpm. It's much quieter in my garage. Well worth the price of 2 gallons of gas for the cleaner.
#207
Super Moderator
It often just depends on how you drive. I've set my RX300 on cruise control a number of times on business trips from Miami to near Tampa and can get as high as about 27 on MPG, but if I floor it around town you can easily see 16 mpg.
#208
Probably doesn't hurt that Florida is Flat too!
#209
My all time record is 27.1mpg on a tank of gas using cruise control at 55mph I drove from southern Oregon to northern Oregon on I-5 which includes several mountain passes.
#210
Super Moderator
