DIY Rear Bumper Cover Removal
Old 04-23-15, 04:53 PM
Pearlrider
Pearlrider's Avatar
Default Removed !!
Old 04-23-15, 05:22 PM
FrogBreath
FrogBreath's Avatar
Like to know if the RCF bumper would fit.
Old 04-24-15, 02:32 AM
Pearlrider
Pearlrider's Avatar
I cannot confirm if the RC-F cover would fit. If the sheet metal is the same I could only "guess" and say yes. But it needs to be confirmed.
Old 04-24-15, 11:50 AM
aWorkOfArt
aWorkOfArt's Avatar
Nice DIY bro! Now if I can just get someone with an RCF to do a DIY I can change my rear reflectors to LEDs like I did with my ISF.
Old 04-24-15, 03:16 PM
Pearlrider
Pearlrider's Avatar
I would venture to say the RC-F comes off exactly the same way. Toyota does not change design model to model. Not cost effective. Plus they are built on the same line and having the same mounting points insures quality.
Old 04-25-15, 01:55 PM
Sherwink
Sherwink's Avatar
Originally Posted by Pearlrider
I've promised a few that I would do this DIY. So hang with me the next couple of days as I complete this task. I understand Toyota bumper covers better than most because I work in the injection molding dept. of TMMK home of the Camry, Avalon, Venza and this fall the Lexus ES. They all share the same basic design.
This is to preceed the F-Sport exhaust swap. Other mfg's rear exhaust kits coming out soon may also use this Lexus round tip diffuser as well.
The diffuser has 8 clips and 4 push pins to attach it to the bumper cover that cannot be reached any other way but by removing it. I tried and its just not possible to get any type of tool needed to remove the clips in the space available. This was a 5 minute job for me once I understood the attachment points and type of fasteners. So follow this and feel comfortable in doing this very easy procedure.
Thank you! Quick question can I remove the diffuser without removing the bumper cover?
Old 04-25-15, 04:42 PM
Pearlrider
Pearlrider's Avatar
"The diffuser has 8 clips and 4 push pins to attach it to the bumper cover that cannot be reached any other way but by removing it. I tried and its just not possible to get any type of tool needed to remove the clips in the space available. "
Old 04-25-15, 09:57 PM
Sherwink
Sherwink's Avatar
got it thanks.
Old 07-14-15, 09:04 PM
shickalee
shickalee's Avatar
On each side of the left and right wings. You will see a black flat looking plastic rectangle shaped holder of sorts. Its on the brim of the cover right in the middle of the bumper cover well. There is a "tab" that locks in place there. It will pull out with a gentle tug. Grip slightly above with one hand and slightly below with the other and pull. It will make a pop sound but do not be alarmed.
I need to replace the drivers side rectangular wing clip pictured above as well as the next clip behind this the rectangular clip, appears to be circular. Does anyone know the Lexus/Toyota part numbers for these clips?
Old 08-14-16, 11:35 PM
dj2020
dj2020's Avatar
@Pearlrider or anyone else, can you confirm this is the same way the bumper cover is removed for a 3IS (2014-2017)?
Old 09-11-16, 10:11 PM
blurcf
blurcf's Avatar
Thanks Pearlrider for a great write up! I was wondering: is it easier with the vehicle on a lift? Or can the bumper be removed just the same with the vehicle on the ground?
Old 09-12-16, 06:23 AM
lexual_rc
lexual_rc's Avatar
Yea this is very basic and easy DIY....no lift needed. I was nervous trying this but everything went smoothly. Why did you take it off tho....bumper light mod?
Old 09-12-16, 07:26 PM
blurcf
blurcf's Avatar
Thanks for the quick reply and reassurance! Good to know. I got a pair of smoked reflectors (no LEDs tho) that will replace the bright red ones. Looks like the only way to remove the reflectors is to remove the bumper. Thanks again man!
Old 04-02-20, 03:36 PM
lexual_rc
lexual_rc's Avatar
Heres what the reflectors with sequential programming look like. I had to replace my tinted fiber optic ones recently due to the wires failing over time. The new set seems to include a thicker gauge wire and I rewired everything better.
Below is a link for the rear bumper removal video as well:
https://www.clublexus.com/forums/rc-...moval-diy.html
krill (09-30-23)
Scarletti
03-26-17 05:18 PM
corradoMR2
RX - 3rd Gen (2010-2015)
12-21-16 05:57 AM
Hayk
09-01-09 02:21 PM
aron7awol
06-08-09 10:17 AM
awol707
01-17-08 08:23 AM
Quick Reply: DIY Rear Bumper Cover Removal
