New owner, issues, help!
Old 05-27-15, 10:13 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Exclamation
I'm going out on a limb here..!!
The hood issues are coming from the factory transport paper / glue...
Joe Z
Old 05-27-15, 11:00 AM
Venturi
Venturi's Avatar
You might be right.
The area in question is on the edge of the curve of the hood above the shock towers on both sides.
there are cuts in the paint about 2 - 3mm long and about .25 -.5mm wide. Only clear coat deep.
I even thought someone manually applying the sheet with brass knuckles on or at least some heavy duty rings
Well, now that its fixed, I'm going to just enjoy it
Old 05-27-15, 04:13 PM
primecut
primecut's Avatar
Ah, so the damage occurred prior to any dealership handiwork! That's a bummer, unfortunately little that can be done about it? I guess it's more practice for you for paint correction
Old 05-27-15, 05:00 PM
Joe Z
Joe Z's Avatar
Exclamation
Unless during PDI, they are cutting off the paper....
~ Joe Z
Old 05-27-15, 05:01 PM
Venturi
Venturi's Avatar
These photos are not very good
I took them after the first compounding attempt but before the 3500 wet sand
So these photos are after the correction process started
Old 05-27-15, 05:03 PM
Venturi
Venturi's Avatar
Another example
I counted almost 40 of these
Old 05-27-15, 05:04 PM
Venturi
Venturi's Avatar
After correction
Steps
Wets sand very little pressure 3500
Compound 3-2-1 and micro finish
Polish
Sealant
Carnauba
Old 05-27-15, 05:10 PM
Venturi
Venturi's Avatar
Hood fully corrected
Hard to capture in a photo
Old 05-27-15, 09:27 PM
zekeman
zekeman's Avatar
Uhh, I think that might be an understatement. I dunno, I guess if you can see it in a casual glance, it's something that might be bothersome. From the photos, I can't see any scratches/cuts.
Z
Old 05-27-15, 10:17 PM
primecut
primecut's Avatar
~ Joe Z
From the pic you posted, it looks like a straightforward peel off, but to your point, I wouldn't put it past them.
Maybe I'm jaded, but I don't really expect perfection anymore, especially if the car has a few miles and has been test driven. When I had bought my ISF, it already had some visible swirls and nicks on it. Nothing drastic but obviously not as new as can be.
Old 05-28-15, 06:10 AM
Venturi
Venturi's Avatar
All true, and I accept that.
I am still curios what's the deal on the self restoring clear coat?
Its even in the owners manual, under care and maintenance, first page.
...but it is not working in any capacity.
I've had a car with the self restoring paint and I was expecting this rc f to have the same modicum of capability.
I'm not expecting terminator stile liquid metal resculpting itself to perfection after a head on collision.
I was expecting whips light marks to soften and melt together to reduce the appearance of the aberration.
The grr had self restoring paint. Worked when warm, such as in the sun and could be coaxed with a hair drier or warm water. The nick in the clear could be massaged or smudged with a gentle microfiber soaked with hot water. about a day later it had melted together. Do it again and the slight light reflection deformation would disappear the rest of the way. That's what I was kinda expecting from this self restoring paint / clear coat .
miguelitos
07-27-18 06:18 PM
alrozrc350
RC - 1st Gen (2015-present)
18
08-01-17 07:15 PM
SRC350F
04-24-16 10:33 AM
DrakanFire
NX - 1st Gen (2015-2021)
05-01-15 05:53 AM
chatrathi
Automotive Care & Detailing
12-11-01 08:47 AM
Quick Reply: New owner, issues, help!
