I took my car in for the 5k service and I noticed that it's missing from the bottom right. I didn't find anything through the car menu to put it back. Anyone know where to find it?
Hit the trip button found to the left of the steering column. Hit cycles from off, odometer, trip A and trip B.
Wow! Almost 28 mpg?? I can barely get 20.
I haven't tried the solution yet, but thanks in advance!
As for the MPG, this was about 30min away from my house. It was all highway driving in Texas, so no hills to go down or up. I normally get around 30mpg on the highway. I am a very passive driver
If, and it's a big IF, I drive normal, in Eco Mode, no passing then I have already gotten over 32 mpg from Tucson to Phoenix. Mostly level and straight road. I do not, however, drive that way most of the time, and I'm happy to be getting only 23 mpg on my daily commute, and having fun along the way.
I get about 18.5 with a mix of highway/city driving...I may have hit 19 on a 2.5 hour drive to NY but NEVER 20. I find I felt the best MPG in normal mode
I used to get the same MPG, but once I put on the CAI I started getting about 3 MPG more.
I just checked mine. Just press the odometer button to cycle through the different settings. One choice is no odometer display at all.
You should be good.
You should be good.
I got it fixed. Thanks! I find it weird that there's an option to simply remove the reading and not put anything in its place.
