RC Credit Card Key
Old 07-11-15, 08:30 PM
cjschober
cjschober's Avatar
Default RC Credit Card Key
So, I just discovered the credit card key that they make. However, they all seem to be specific for each model. Does anyone have one for the RC350? Or does anyone know if they make it for the RC350? I've long carried my keys on a carabiner for ages and amongst the fact that you can hear me coming a mile away, they also have a tendency to rub up and scratch alot of things. So this gives me a good reason to go keyless. Any help on this matter would be appreciated.
Old 07-11-15, 09:40 PM
ZAM
ZAM's Avatar
Yes, there is one for the RC 350. The part no. is 89904-53511 / HYQ14CBB. Here is an ebay link as well: http://www.ebay.com/itm/Lexus-RC350-...-/111625490861.
You're going to need your dealership program they key. And, the physical key would also need to be cut if you want to use it.
lexual_rc (04-24-19)
Old 03-23-19, 09:16 AM
Pittsy
Pittsy's Avatar
I know this topic is beat to death on this forum but i have the same model key, and was told by my dealer that it was not able to be programmed to my RC...
Old 03-23-19, 12:17 PM
Pittsy
Pittsy's Avatar
Just an update. got Techstream and everything needed to program the key... The car sees the key, but because it’s a used key, it won’t program. anyone know how to reset this key?
Old 03-25-19, 08:40 AM
350phi
350phi's Avatar
you need a seed code. google "Lexus seed Code" weboctopus.nl should have codes for you to purchase.
These are the codes needed for techstream to reset your key fobs so you can program used fobs to your car.
basically you're going to clear out all your key fobs, it's a 15min process. then you re-add all your fobs then add the key card at the end.
Old 03-25-19, 09:33 AM
Pittsy
Pittsy's Avatar
Yeah I figured out i needed a seed code when I tried resetting the Smart Access Codes. Unfortunately WebOctopus doesnt work on the latest version of Techstream. I bought a code from them and it didnt work. WebOctopus said the version is invalid. Going to get the security professional membership on TIS and try it out again. That is why TIS wasnt letting me create a seed.
Old 04-14-19, 06:50 PM
Chris802
Chris802's Avatar
Have you had any luck connecting a new key to your car?
Lexus Australia quoted me $830 for a new OEM key. So I asked my local locksmith and they said they can't make any spare keys for me at all.
I have pulled apart my key to look at the chipboard inside. I have chipboard number 281451-2020. I can order this part including the whole key online for $82US plus postage.
Please let me know if your able to get this to work.
Old 04-14-19, 06:53 PM
Pittsy
Pittsy's Avatar
If it’s a brand new; unused key or chip; then yeah, it’ll work no problem.
Chris802 (04-15-19)
Old 04-14-19, 07:03 PM
Chris802
Chris802's Avatar
Will I just need one of these?
https://www.ebay.com/itm/For-Toyota-...d=283189391167
Where does it plugin?
Old 04-14-19, 07:39 PM
Pittsy
Pittsy's Avatar
Plugs in to the obd2 port under the steering wheel. you’ll need a subscription to TIS, like 60$ for two days for the subscription you need to get access to tech stream. tons of videos online on how to install the drivers and everything you need.
Chris802 (04-15-19)
Old 04-24-19, 08:16 AM
lexual_rc
lexual_rc's Avatar
^^What he said. It definitely exists and programming at local Lexus dealer is possible and done very quickly. I had to find a locksmith however who could cut the physical key which was the harder part of my experience...but that was just because there weren't many located close by.
Old 04-25-19, 02:16 PM
ideutsch
ideutsch's Avatar
I just had the blank card key cut at my local dealer, part number is 69515-30350. I can also attest that the aforementioned key card (89904-53511 / HYQ14CBB) also works on the 2019 model.
It would be great if Lexus offered these card keys with the vehicle purchase. I find it to be much more convenient than carrying a key fob and worth the cost.
Old 04-26-19, 08:06 AM
Pittsy
Pittsy's Avatar
For real. Im trying to sell my old one and get a new unregistered one so I can finally do this...
Old 04-26-19, 09:07 AM
sideswipe
sideswipe's Avatar
Got one as well and its great. I also had Lexus send me a pre-cut key instead of hunting down a locksmith to cut it.
Old 05-16-19, 01:19 AM
Chris802
Chris802's Avatar
Sorry for posting in the RC Credit Card thread but thanks for pointing me in the right direction regarding the proximity key. I thought my Australian car may not pair with an American key or have a compatible OBD port but everything worked well. For the physical key, I just had it cut at my local shopping center.
Quick Reply: RC Credit Card Key
