GS 470 - Yup a 2uz in a GS400. Done!
Old 10-09-16, 05:00 PM
  #31
plex
1UZFE/2JZGTE
plex's Avatar
Any new updates? Toying around with idea of 4.7 shortblock with my OEM 1UZ head. Doing a lot of research and reading.
Old 11-03-16, 11:46 PM
  #32
TheOnly1UZ
TheOnly1UZ's Avatar
Awesome would still love to see dyno numbers.
Old 05-24-17, 02:10 PM
  #33
PureDrifter
BahHumBug
PureDrifter's Avatar
Why would you do this, there's literally no benefit...?
Old 05-25-17, 07:37 AM
  #34
plex
1UZFE/2JZGTE
plex's Avatar
Boredom and itch to do something lol.
Old 12-27-17, 01:40 PM
  #35
wpatriot80
wpatriot80's Avatar
Inspiring project! I got a LS430 with over 200k miles and when the 3UZ faces its death I might have to pair the 3uz heads and other parts with a fresh 2uz block. Of course the build has to be planned so that the power output numbers won't go downwards with extra displacement.
So keep the info coming if you have same type plans.
Old 02-22-18, 03:28 PM
  #36
PureDrifter
BahHumBug
You would be better off going 2uz VVTi, afaik the 2UZ vvti heads flow the same and the 3uz heads/2uz block requires custom pistons.
Old 02-23-18, 03:51 AM
  #37
wpatriot80
wpatriot80's Avatar
Yes sir 2uz vvti is a good package as it also has better plastic intake manifold. That could also be paired with bit more aggressive 3uz cams (?)
I've done some research after my last message, and for my needs some custom work has to be done in any case. That's cos I want atleast 10:1 compression for going NA (and e85 too).
The pistons have to be modified because 3uzs steeper valve angles, and 2uzs stock mugs can be milled to work with them. Then it'd still have compression somewhere in 8-8,5.
I got about $600 quote (good deal to me) for longer rods but then the piston surface profile & quench areas and all that would be a mystery.. Well designed custom pistons would be the best option.
It is hard to take measurements and plan stuff since my only UZ parts yet are in my daily but I'm definately going 2uz route when rebuilding. Research goes on (Y)
Old 10-27-20, 11:27 PM
  #38
howie954
howie954's Avatar
have u perfected this swap yet? Such an interesting read 👍🏽👍🏽👍🏽
ThatGuyJ
01-03-19 05:10 PM
outareach
12-16-13 07:47 AM
beecuzwhy
Performance
19
10-05-06 09:46 AM
beecuzwhy
09-30-06 05:29 PM
Quick Reply: GS 470 - Yup a 2uz in a GS400. Done!
