F sport exhaust too quiet?
#31
After reviewing the pictures, I do see my Y pipe is a little different, didn't know that there could be other possibilities in y pipes.
I've put the Megan racing mids on and the sound has definitely improved.
Could someone verify if there are aftermarket Y pipes or replica Y pipes for the f sport exhaust?
#32
I have the newest version bought new from Sewell Lexus and it looks the same as the OP except mine is polished stainless and his does not look like stainless. I will take pictures when I have time.
Jeff
#33
So did you see my post, it is the one before your last post. check the pictures
Jeff
Jeff
Side note- does your exhaust tip protrude out a tad too much? My tips def stick out a little bit. I feel without a rear lip it looks slightly out of place.
#35
I have the F-Sport engraving on mine and a Y pipe (not the T pipe that the OP has).
Most of the exhaust comes out of one side and you can see that because one tip is significantly blacker than the other.
Exhaust used to have a lower note and louder when brand-new, now it sounds smoother sort of like a V8.
