F-Sport Performance Intake -- INSTALLATION (w/PICS)
Hello,
So like many of you I have been researching what type of intake to install in my 2014 Lexus IS350 F Sport. Finally after reading countless posts I decided to go with the Lexus F Sport Intake.
My initial thoughts after install are as follows. It's very throaty and about 3,000 - 3,500 RPM it sounds amazing. Inside the cabin it's not very loud but can definitely tell it's there. I would rate the sound at 8 out of 10.
Here is my DIY guide if anyone else needs any help.
Difficulty Level: Low
Tools Needed
10mm socket
Standard Pliers
Needle Nose Pliers
Phillips Screwdriver
1) Loosen the M6 bolt that is securing the negative terminal for the battery.
2) Remove all the factory components
Pics of the process below. Hope this helps for anyone looking at this mod. I also included links if you would like to see step-by-step install.
http://i1189.photobucket.com/albums/...656272_HDR.jpg
http://i1189.photobucket.com/albums/..._115953576.jpg
http://i1189.photobucket.com/albums/..._120054793.jpg
http://i1189.photobucket.com/albums/...427766_HDR.jpg
http://i1189.photobucket.com/albums/...638459_HDR.jpg
http://i1189.photobucket.com/albums/...744641_HDR.jpg
http://i1189.photobucket.com/albums/...826546_HDR.jpg
http://i1189.photobucket.com/albums/..._120913686.jpg
http://i1189.photobucket.com/albums/...110800_HDR.jpg
http://i1189.photobucket.com/albums/..._121147341.jpg
http://i1189.photobucket.com/albums/...318329_HDR.jpg
http://i1189.photobucket.com/albums/...029883_HDR.jpg
http://i1189.photobucket.com/albums/...330490_HDR.jpg
http://i1189.photobucket.com/albums/..._122429636.jpg
http://i1189.photobucket.com/albums/...550312_HDR.jpg
http://i1189.photobucket.com/albums/..._122943944.jpg
http://i1189.photobucket.com/albums/..._123034350.jpg
http://i1189.photobucket.com/albums/..._123122690.jpg
http://i1189.photobucket.com/albums/..._123219115.jpg
http://i1189.photobucket.com/albums/...321192_HDR.jpg
http://i1189.photobucket.com/albums/..._123542880.jpg
http://i1189.photobucket.com/albums/..._123653424.jpg
http://i1189.photobucket.com/albums/...026437_HDR.jpg
http://i1189.photobucket.com/albums/..._124055222.jpg
http://i1189.photobucket.com/albums/...220210_HDR.jpg
http://i1189.photobucket.com/albums/...910151_HDR.jpg
http://i1189.photobucket.com/albums/...148550_HDR.jpg
http://i1189.photobucket.com/albums/..._130146221.jpg
Ricky
Tools Needed
10mm socket
Standard Pliers
Needle Nose Pliers
- Loosen the inlet tube hose clamp at the throttle body
- Squeez the clamp on the PCV Hose. Slide it back-n-forth til it comes loose.
- Use a pair of regular pliers to unclip the hose from the retainer on the side of inlet tube
- Next, unplug the MAF sensor
- Use your needle nose pliers to unclip the wiring harness from the side of the factory air box.
- unclip all 4 retaining clips on the air box lid. Remove it all together.
- Carefully remove the factory air filter
3) I put a towel on the floor and removed the MAF sensor from the factory air box.- Install the MAF sensor on the F Sport AIr Box Lid (be careful not to stripe the screw)
- put in the new F Sport air filter (good time to blow out box with leaf blower and wipe clean)
- Install the coupler and hose clamps on the throttle body. (make sure hex heads are face up)
- Insert the F-Sport intake tube into the coupler. Make sure you don't tighten it yet til you have it properly fitted.
- Insert hose clip into retaining bracket on F Sport intake tube. You should hear it snap when it clicks into place.
- Attach the PCV hose to the F Sport intake and go ahead and secure the clamp. After instsalling your bellows make sure your hex heads are face up.
- install F Sport air box lid into the bellows and lock in the 4 clips.
- Hook back up your MAF sensor and secure the wire clip to the side of the F Sport air box.
- Tighten the coupler and bellows hose clamp at TB air box. Torque to spec (30in. lb. 5 in-lbf)
4) Put your engine cover back on and reconnect the negative battery terminal. At this point you can slap on the label but I opted not to since I'll be doing all the general maintenance.
Ricky
rgonza1
01-12-15 04:51 AM
