JoeZ exhaust too loud or drone?
Old 06-13-14, 08:07 PM
dkha
dkha's Avatar
Default JoeZ exhaust too loud or drone?
Just installed my joeZ axle-back exhaust. Either the exhaust is very loud or i didnt install it right. under 3000 rpm it feels very deep and loud.
When cruising on the hwy at around 100-115 km/h it seems to drone. only when you let off the gas pedal the sound goes away.
When car is parked it rumbles slightly? is this normal? or did i install it wrong? but it seemed very straight forward, had a professional shop do it.
Old 06-13-14, 09:04 PM
CJW
CJW's Avatar
Likely normal. Full catbacks are usually a bit dramatic at first, then you get used to it.
I did an axle back and normally, it's about perfect for a car that's a mix of luxury and sport.
Old 06-13-14, 10:44 PM
gvan1998
gvan1998's Avatar
Thats why I chose f sport exhaust. Perfect loudness.
Old 06-14-14, 09:59 AM
ultran00b8
ultran00b8's Avatar
I think it's normal. The JoeZ has a really deep sound which I like under 3,000 RPM. Did you remove your resonators by any chance?
Are you sure it's actually drone or just the exhaust note? The drone I had before putting in aftermarket resonators was deafening and basically caused everything in the cabin to vibrate and shake.
Old 06-17-14, 05:09 AM
iRyan
iRyan's Avatar
I have the axle back alone and I have no drone at all and under 3k i can barely even hear that thing...the cat-back I know is deep but if u have axle you shouldn't really hear much to where it's noticeable....check the screw and make sure there's no leak
Old 07-07-14, 04:43 PM
daobn24
daobn24's Avatar
Anybody delete the 2nd cat with the Joe Z axle back? I'm thinking about doing this. Just wondering what it'll sound like.
So it would be primary cat - delete 2nd cat - stock resonator - Joe Z axle back.
Old 07-09-14, 11:47 AM
JB5674
JB5674's Avatar
It's been done....the res delete
I believe there is also you tube videos of this too
MpKSonic
IS F (2008-2014)
16
04-15-17 10:17 AM
GsLex02
06-03-16 04:10 AM
kevinktai
Performance
25
10-28-15 07:47 AM
amaar93
01-12-15 10:15 AM
Quick Reply: JoeZ exhaust too loud or drone?
