Rock's SC install is finally done!
Old 07-17-14, 09:25 AM
  #31
Mr Johnson
Mr Johnson's Avatar
Awesome to see it back in a car and running! Great job putting it all together. Really didn't think this would ever happen. Congrats and Enjoy!
Old 07-17-14, 12:23 PM
  #32
Rock-a-Lex
Rock-a-Lex's Avatar
Thanks man! I really appreciate your help in PM. You helped me along the way with some Q&A I had since you were the original owner of this kit.
Old 07-17-14, 02:59 PM
  #33
SweetS160
SweetS160's Avatar
Looks great and congrats on the install. Back in the day when I was boosting my old gs3 I put the fic in the glove box to the right in that pocket. I had the boomslang harness as well. It makes it all the way to the engine bay and in the ecu box with about a foot extra. I cut a slit in the firewall groment and fed it threw there and ran it zip tied to the wiring loom from the firewall to the ecu box. Fyi I was going to mount it on the ecu box as well at first lol
aka Sleeper2jz
Old 07-19-14, 12:20 PM
  #34
GeorgeGS4
GeorgeGS4's Avatar
Looks great man, congrats on a clean install
The real question is have you felt an increase in power over stock?
Old 07-19-14, 11:04 PM
  #35
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Hey Rock, time to update your signature....
Old 07-20-14, 06:57 AM
  #36
Rock-a-Lex
Rock-a-Lex's Avatar
I'm sure it creates a lot more power but I haven't gotten a chance to test ask I cannot hit boost on the stock ECU. AEM said they should have my FIC back to me by end of next week; hopefully they found something wrong with it and fixed.
Old 07-20-14, 07:50 AM
  #37
Rock-a-Lex
Rock-a-Lex's Avatar
Done!
Old 07-26-14, 02:13 PM
  #38
Ar1st0
Ar1st0's Avatar
Sick setup!
Old 10-20-14, 01:25 AM
  #39
clos430
clos430's Avatar
Any updates on this Rock ? Hopefully it's running great and we can see this in action. We need some video!
Old 11-14-14, 05:07 AM
  #40
tmf2004
tmf2004's Avatar
do you have a new Video?
Old 11-26-14, 06:47 PM
  #41
speedaddic
speedaddic's Avatar
having issues with that FIC still? I got rid of mine and did the Haltech platinum standalone. No issues since.
Old 11-27-14, 03:48 PM
  #42
Rock-a-Lex
Rock-a-Lex's Avatar
Unfortunately yes. Burning through tuners and money like it's going out of style with no sign of light at the end of the tunnel. Past frustration.
It's all about my car stumbling at idle in closed loop after it's warmed up. This is preventing my last (2) tuners from being able to tune it. Had the latest tuner look at it and he totally feels that the tune is the problem and feels he can get it right. I read something somewhere that it could even be my injectors. They are 13yr old RC440's. Even though I got them professionally cleaned I have read that the old technology and shear age can be the culprit. But then I ask why is my idle nice and smooth when the FIC isn't connected? This is why I feel it may not be my injectors after all.
All I know is that I think the last tuner pulled too much timing...over 20 degrees up top when I read that others making more boost (15psi or so) are only pulling 7 or 8 degrees of timing. Too much retarded timing may be telling my car to run rich even when a Crap ton of fuel is being pulled out of my fuel map at low RPM (idle). I think I am going to try to bring my timing down to -8 degrees up top, then see where the fuel is at and enrich or lean out from there.
This is where I'm at. Other than suggesting a full standalone if you have any tuning advice or can comment I'm all ears. Thx
Old 11-28-14, 10:08 PM
  #43
badblackgs
badblackgs's Avatar
hey this is badblackgs. I sent you a private message in regards to your idle jumping up and down when warmed up. check your messages. I had the same problem until I whipped out the magnifying glass and began questioning everything.
Old 11-28-14, 10:14 PM
  #44
badblackgs
badblackgs's Avatar
also, if anyone is interested. I posted a bunch of pics of my turbo build on my 2002 gs430. yes that's right, 3uz single turbo. running and frickin bad ***. im happy to answer any questions. im just really excited to be apart of the club lexus community now. the pics are in my gallery.
Old 11-30-14, 04:58 PM
  #45
Rock-a-Lex
Rock-a-Lex's Avatar
On the road to success! With the help of badblackgs I am straightening out the wiring in the $360 "plug and play" Boomslang harness I bought...not so much plug and play. I suspected the wiring was messed up but went through it again after the recent help I got and sure as anything the Cam and Crank wiring was jacked up. I will try to get my newly corrected harness to the shop where my car is at in a day or so. I'll keep you all posted. Thanks
Quick Reply: Rock's SC install is finally done!
