beefing up my 93 lexi
Hi, this is a first timer. I have a 93 gs300 with a 94 supra 2jzgte engine swap. I'm in the process of putting a single precision cea 6466 turbo on it. I'm trying to figure out what all else I need to replace in order to support the higher horsepower and suggestions on which brands to go with it. I have a quick spool valve and 800 cc fuel injectors, a cast iron manifold, a precision wastegate, the mid/down pipe, New fuel lines, and a filter for the idle speed control valve. What part of the suspension needs replacing for this and what kind of transmission/header work should I look into as well? Thanks for your help!
Eric00GS3
03-20-21 05:24 AM
