Need to possibly replace transmission - questions
So I'm not sure exactly what happened but turned my car on today and it wouldn't shift past 3 and vsc turned off. I'm thinking the transmission has gone bad and I'm out of warranty. It had been shifting really hard for a while now. I have a 2007 is350.
I'm thinking I might have to replace the transmission which will undoubtedly suck but I was thinking that if I'm going to be spending so much money anyway is there any possible way to convert this to a manual transmission... I saw pages of it online with people asking about it but not sure if it's been done or if it's even possible. I really don't like the transmission that's in the car. Even if it working fine it's so laggy in the shifts and not that smooth at all.. The only problem I have with the car
if i were you i would just search around for another auto 6spd for your is350. the shifts really arent that bad unless you want the car to shift like an f1 car. manual trans really isnt the answer for the "laggy shift" thing because unless you are beating on the car, you wont be able to shift as fast as an auto. the human factor alone would slow the car down
as long as this motor/trans been around im sure it cant be too too expensive nowadays. good luck man
