Electrical Prob....
do you know how to use a multi meter? Set to amperage and place the meter inline between the posi terminal and the battery - if higher than .05A....start to pull fuses until the amperage drops below .05...then check the circuit for draws
If your driving it everyday and it's dying it's either parasitic draw....blasting the radio....might be a bad regulator in the alternator. ...quick on to check is if buttons are stuck anywhere seat adjusters or memory ect...
this is the best way to find out what is going on
MoeSzyslak
03-10-14 02:28 PM
