GS430 Better Tranny shifts just by adjusting dial?
#79
http://lexus.sewellparts.com/oem-cat...S300-2000.html
this is the one for the Gs400/Gs430
STRAINER ASSEMBLY, VALVE BODY OIL Part #: 3533030070 $40.05 from sewell
http://lexus.sewellparts.com/oem-cat...S430-2001.html
along with that get this guys...
F.I.P.G.-Form-In-Place-Gasket (Transmission) Part #: 002950128 $16.68 from sewell
http://lexus.sewellparts.com/accesso...XUS-/4928.html
#85
#87
Who ever dropped my tranny pan before caked it up with gasket maker. I had a hell of a time getting the pan off. I adjusted the regulator to the third position and it has helped with the problem I was experiencing. When I first drove it, it almost felt like it was in sport mode while in normal. That would be the best was I could explain it. I would recommend this if you haven't already.
And it took me 3.75 qts to refill. I used on old milk jug to catch the tranny fluid so I could measure the old and refill the new. I made the mistake one time of just drained the tranny not paying attention to the amount of tranny fluid I took out in one of my old cars and it never acted right after that.
#88
My first attempt in removing the tranny pan failed. I put the bolts back on, but now oil leaks from almost each bolt... Once you start , there's no way back..
So now I will try with a sharp/thin putty knife and a rubber mallet.
Few questions:
1. I have read putting a jack under the pan and jack it up slightly will put pressure on the seal and break it? Has anyone tried this method?
2. Do you need to unbolt the refill tube? Or is it just plugged in the pan??
Thanks
Few questions:
Thanks
#89
Guys... use a wide thin chissel...the wider the better, that way you can distribute the pressure more evenly so that it won't bend the pan.
Rubber gasket is available from the autozone, etc... it's a couple bux, you don't need the toyota red gasket.
When tightening the bolts... make sure you torgue it evenly. Start from each corner, then middle sides, etc... then go back and tighten everything up.
Make sure the tranny tube is fitted first before bolting the pan back on.
#90
Few questions:
Thanks
Few questions:
Thanks
As^^ said you a chisel as wide as you can find would be one of the easiest and safest to keep from bending. I used a razor blade and tapped it with a hammer till I broke it loose
