JDM 2jzgte vvti swap GS300
#92
Unsure?
So Ive been reading this thread for some time and I see you guys are talking about a Trac/abs/vsc ECU? Is this something I will need in order to complete my swap? Or is it something that comes with the harness? Where is it located on the JDM harness? My harness came with the engine harness,ecu part of the front body harness and both fuse boxes.
#93
#95
#96
I take that back i thought you were talking about the trac/abs/ect ecu lol, the vvti gte ecu goes for about 250-350 on yahoo japan give or take now the tuned ecu's are the ones that they tax you on from 750-1200 for a toms or mines ecu lol.
#97
#98
I still have to locate mine. I'll post a pic of the location later today stay tuned. And yes they are not usually included you can request it if you are getting a full clip, if you are lucky you will get it. And no it I not located in the engine bay. it is located in the car. I wanna believe in the back I the cabin where the cabin air filter is located. Not too positive, but I'll let you know.
#99
If its tuned.., that's a whole nother level! I would pay 550 if it's tuned, But this was a bone stock ecu. That same day I called another company and got it for 200 ship.
#100
There are two 10mm nuts holding it on, the usdm and jdm modules are the exact same size and pin/connector configuration, but the jdm is mounted on the other side of the car so the thin metal mounting tabs on the housing don't line up directly as the jdm one was on the right side of the brake pedal not the left side, so it is opposite.. It's easy enough to bend the tabs some or use zipties to hold it up in place.
#101
here is the location. follow the lables. driver's right foot, above the gas padel or next to it I believe.
#102
I've changed out a few of these, and in my manual swap car the 105 wire harness was extended 5ft so I could mount abs/vsc/trac module inside the gutted cd changer housing along with the mapecu3 piggyback, usb hub, innovate wideband serial convertor, and hks evc easywriter adapter.. .
Yeah that is the proper diagram, although those line drawings are difficult to orientate depth, it kinda only shows the general area.
There easy to access, there is just no slack on the wiring..
#103
As I stated in the previous post it is to the left side of the brake pedal. It's easy to see without removing the dash panel under the steering wheel, can't miss it as it's huge.
#104
okay guys, my swap been going okay. i founded out that my car has two body plus that does not plug into the gtevvti ecu. at first i thought it was because i dont have the gray immbobilizer plug for some reason. two i didnt wanna put up with reflashint the car to get it started so i did some research and got the ecu without the gray connector. problem still remains, those two body plugs does not plug into the ecu. I did some run arounds and i found the part numbers for the right connectors called toyota and ordered the two of them. they will be here on tuesday and i will start the wiring. i know its going to be a headache but i'll get it done. I just wantede to stop by to see if anybody been down this route before to please give me some pointers as to what to watch out for. I could probably run to some junk yards and find a 160 gs and cut those connectors wit wires still attached and match up wires with a spec sheet to be sure but i thought i ask for some help first.
this view shows my stock ecu and as you can see there is no gray plug.
these are the plugs that doesnt plug in directly.
immobobilize and non immbobilizer
connectors i need to switch over
actually I'll take that back, E2 and E3 has to be switched over, correct me if im wrong.
Now, i got a good spec/ pinout from ";Wilbo666" for the 2jzgte vvti. they have a lot of info for toyota cars. my concern here is that this is what i got for the car itself from alldata. unless im not reading it right.. but it really isnt helping. sorry about the picture quality. there is another page but what you see below the connectors is basically what the other looks like.
I found this around here which is alot better but it doesnt have everything in it.
so yeah, other than this everything is ready for finish up. fuel reture was completed lastnight, im just waiting for my jet killer to completely seal the gas tank. i also still have to connect my tech wire, but the igniter is hooked up as well. so somebody, anybody if you know or have any clue please help. its a really busy month for me. I still have to do my singo turbo conversion on my S147 but i have to get this over with before i start on that.
