HKS350 does it again! Living up to the title..
Old 10-20-11, 01:18 PM
  #331
HKS350
HKS350's Avatar
Just buy a jumper hardness and wire in according to the instructions. Send the unit to me and I'll have the map loaded in it.
Easy. A few company's will make a jumper harness if you take a picture and send them the factory pinout. I used boomslang http://www.boomslang.us/
Other good info is http://1jzmerc.com/hks-faq/hardware/f-con-iS
Old 10-20-11, 01:35 PM
  #332
ISF4life
ISF4life's Avatar
, hummnn
Old 10-21-11, 08:23 PM
  #333
birador
birador's Avatar
that's what you call,godzilla power
Old 04-18-12, 09:55 AM
  #334
Kingdavid
Kingdavid's Avatar
Originally Posted by HKS350
Found out you can push these motors to @ 550 HP before the stock crank fails. So 500HP on a good tune can be a daily driver. Been told the transmissons hold up well to @ the 500HP mark also.
I must be confused. You're talking a 2jz right? Not a 2gr.
Old 04-18-12, 11:36 PM
  #335
fsport124
fsport124's Avatar
So u can use this tune with an n/a car, ior it must be supercharged
Old 04-19-12, 08:03 AM
  #336
Kurtz
Kurtz's Avatar
You could use it NA, but I doubt you'd see more than 10 hp out of it- which isn't much for $1000+
Old 04-20-12, 01:36 AM
  #337
fsport124
fsport124's Avatar
Hks350 how much power r u running
Old 07-29-12, 04:11 PM
  #338
HKS350
HKS350's Avatar
The supercharger kit is forsale in the 2IS section!!!!!!
Hurry before its gone!
https://www.clublexus.com/forums/is2...r-forsale.html
Old 07-29-12, 05:51 PM
  #339
heyarms
heyarms's Avatar
I think a little part of me just died inside... Loved your car and how well documented and all the work you put into boosting it.
On a side note, a guy at EVS Motors in Houston that worked on my car said he used to live by you and knows you. Haha small world.
Old 08-18-12, 07:01 AM
  #340
jag87
jag87's Avatar
I hope that you still have the OSC running with iS HKS ECU.
I have iS too installed and running perfect but recently I acquired the OSC box near new
however it has got harness missing and of course no plugs.
I could see on your 1st page picture of this thread nice wires on connectors to the OSC
but in low resolution.
Is it possible that you provide a few pictures with higher resolution of the OSC connectors from
top row and the bottom row of pins and also the other end of the harness where the wires are
connected to the HKS iS harness or the iS ECU or else.
I can then built the harness from the pictures and hope to run the OSC box with iS ECU.
If its possible could you email the picture and if you have any connection diagram of the OSC box.
Nixcision
Performance
09-25-15 10:23 AM
Bippu147
02-26-15 04:51 PM
XxPainxX
SC400 / 300 Classifieds
03-24-13 07:54 PM
5spdSC300
10-01-08 03:23 AM
MeAn_GrEEn
Performance & Maintenance
24
11-10-04 09:06 AM
Quick Reply: HKS350 does it again! Living up to the title..
