ProjectGS DIY: ECU Pinout
Old 11-29-10, 02:23 PM
GILLEXUS
GILLEXUS's Avatar
Jeff so guys don't get mixed up the color coded plugs are viewing thm from the ends not the top in other words the numbers are reversed on the actual ECU - correct?
Attached Thumbnails ProjectGS DIY: ECU Pinout-jeff-pin-outgs300-01-05rev.jpg
Old 12-16-10, 09:18 PM
criminalR1
criminalR1's Avatar
all I want for Christmas is a GS400 pinout...........
Old 12-17-10, 01:21 AM
aka paco
aka paco's Avatar
Thanks man, hoping to tackle a GTE swap in a 02 SD soon..
Old 12-17-10, 06:24 AM
GILLEXUS
GILLEXUS's Avatar
here ya go 2 of them
Old 12-20-10, 05:44 PM
gregmessic
gregmessic's Avatar
A mechanic told me that my ECU is going out... Do you know if I install a used ECU does it need to be reprogrammed?
Old 12-22-10, 05:01 AM
GILLEXUS
GILLEXUS's Avatar
I'm not sure, I thought you needed to reprogram your master key unless it is a defferent ECU for that.
Old 12-22-10, 03:22 PM
criminalR1
criminalR1's Avatar
it will need to be reprogramed if you dont have a matching key.(call around to you local lcksmith if you go this rout much much cheaper than dealer) ..if it comes with the matching key all u have to do is swap over the chip to your existing key and wall..A....(otherwise it will not disable the immobilizer and start if the key and ecu are not paired)......
Old 02-16-11, 09:39 PM
jacksonvp
jacksonvp's Avatar
Do you have a VVTi GTE JDM pinout?
Old 07-18-11, 08:35 PM
LexCafe
LexCafe's Avatar
I' in the process of wiring the fi/c. The ecu pinouts that Jeff posted are positive (+) right? So all of the positive wires from the fi/c would connect to those but where do you connect the negative wires from the fi/c? (crk-, cam-, inj-, ect...) Please help.
Old 07-20-11, 11:31 AM
qphoton
qphoton's Avatar
For GS2 '98-00 with 2JZ-GE VVT-i you can use IS300 '01 pinout:
01pinout.xls
where
ProjectGS DIY: ECU Pinout-is300-01-ecm-1.gif
Also for GS2 '01+ you can check IS300 '02+ pinout (don't sure):
02+IS300_ECU_Pinout.xls
Old 07-20-11, 12:09 PM
qphoton
qphoton's Avatar
Full Lexus GS300 '98-05 Wiring manual you can download here
Lexus GS300 1997 - Wiring.zip
just enter code shown below.
onn the next page you need uncheck checkbox and click on the link above, download will start
Old 07-22-11, 11:40 AM
LexCafe
LexCafe's Avatar
Thanks. I had a brain fart few days ago but had it figured out. Had the fi/c hooked up and running. Now it just a matter of tunning to make it run right.
Old 07-22-11, 12:40 PM
gijohnnyb
gijohnnyb's Avatar
You are a God-send!
Old 08-21-11, 06:33 PM
nezlyfe
nezlyfe's Avatar
thanks needed this for an o2 sim
Old 08-29-11, 07:02 PM
Rande
Rande's Avatar
love the pin out. question would be is do you or anyone know when i can get the wiring lay out for the jap spec aristo harness
Quick Reply: ProjectGS DIY: ECU Pinout
