IS250 AWD to IS350 brake conversion part list
I can't seem to find a list outlining all the parts I will need to do this conversion. Can someone please help?
So far I know the followings are for sure:
- Calipers, front and back
- Disc, front and back
- brake pads, all four corners
- dust shield, IS THIS A MUST????
- Brake lines????
am I missing anything else?
thanks
- Brake lines????
thanks
You can use your regular brake lines, unless you want to upgrade to stainless steel. Also the front does require a dust shield, you can modify it by cutting it, the rear needs to be cut if you're installing the rear caliper. Actually I believe you can also just bend it and it should fit fine
lexus is250 converstion to lexus is350 big brakes
Wassup everybody I have a 2006 Lexus is250 and I want to convert the is250 to the is350 big breaks what are the things I need to change and buy I called the dealer and they said I might need to change the knuckle where the rotors sit on can yal help me out and I know theirs no point in putting them but for looks thanks
viettho
Suspension and Brakes
17
04-04-07 07:16 PM
