Twin-turbo vs. Supercharger
Hey i was wondering if i should twin-turbo my is300 or supercharge it. I can get a supercharger which will be smog legal in califrnia and cheaper but a twin-turbo will bring more power. Please give me some advice on where to go with this.
Depends on what you want personally and how much money/time you're willing to spend. A Twin turbo system will obviously net you more gains over a supercharger, the possibilities with a turbo are amazing. A supercharger will give you more consistent gains over the entire RPM range, while with the turbo you can experience turbo spooling or turbo lag. Furthermore, a supercharger is overall easier to maintain and a straightforward method of forced induction. But if you have the money, will, time and the right people to do the install and tuning, then go with the turbo. Otherwise stick with a supercharger and safe driving
twin turbos would only be useful if you swapped in a 2jz gte or built your engine to handle the power.
i would just stick to a single turbo if you where to go the turbo way.
it really depends on what power level your looking for with a super charger you can get 300whp with out even opening the engine up.
i think that supercharged cars are alot nicer to drive
I have someone that will hook me up with a vortech supercharger but by their dyno test it only ups the hp by 90. While a single turbo will give me more hp but will cost almost 2k more and not street legal.
If you're looking for a TT kit the only one I've seen is the HKS kit for the GTE. But is like 12k. Cheaper to do a Aristo/Supra swap. A 1JZ swap is even less. More reliable in the long run because you'll have the GTE internals also. NA-Ts aren't as reliable and are break down more depending on the power.
If you want an SC there are a few for sale on isfanatics.com. You can PM a guy over there named RaptorV1. He has a Raptor SC and it's very well. Seen it in person.
i noticed you live in ca. no supercharger kit was ever made for the is300 is legal. the only legal way is a tt 2jgte motor swap from a supra if you are living in ca and you would need a obd2 motor
Much more work required for a turbo job, especially if your planning to do a twin turbo. It's harder to find a TT manifold for the 2JZ-GE. Much easier to get a TT manifold for the 2JZ-GTE, so you might as well do a swap for it.
Otherwise, for the 2JZ-GE, a single turbo would probably yield higher gains in the long run. You'd need to start doing internal upgrades if you plan on boosting over 7-8psi, things like headgasket and such would need to be upgraded on the GE motor.
CA is going to be alittle harder to find a CARB approved set up, but they have to have them, its california for gods sake. They are the tuner capital of the world
I've heard that you can do an aristo head swap on our ge block and use the stock is300's ecu to make the swap to twins easier. I'm looking at either doing that type of swap myself or going with the 3sge off the JDM altezza. Still can't decide if I want good mileage or straight power.
