LMS SC with some methanol injection
Old 06-25-07, 09:14 PM
t0e
t0e's Avatar
fstrnldr? Are you a new tech at LMS?
Old 06-25-07, 09:44 PM
pylee257
pylee257's Avatar
yeah he is. i went there a couple days ago and talked to him about the SC
Old 06-25-07, 10:55 PM
ddquach
ddquach's Avatar
thanks for posting, I didnt get around to do so... a little lazy.
Old 04-02-09, 08:16 AM
iSuxeL
iSuxeL's Avatar
Bump for D D D D DJkhanvict!
Old 04-02-09, 08:31 AM
IAMJAVEDG
IAMJAVEDG's Avatar
thanks john haha
Old 04-02-09, 08:39 AM
Robs IS250
Robs IS250's Avatar
hmmmm! LOL
Old 04-08-09, 08:59 AM
x2mkx
x2mkx's Avatar
ok time for a nub question that will bump this post a little bit :P
what exactly does methanol injection do? and what is it doing in conjuction with the SC kit?
Old 04-08-09, 10:03 AM
Kurtz
Kurtz's Avatar
It acts like a chemical intercooler, as well as (in meths case) raising octane a bit... so you can run more boost without risk of detonation.
Old 04-08-09, 10:05 AM
iSuxeL
iSuxeL's Avatar
Alcohol/water injection is a method for cooling the combustion chambers of engines by adding methanol/water mix to the incoming air-fuel mixture. This allows for greater compression ratios and largely eliminating the problem of engine knocking due to detonation. Many alcohol-water injection systems use a mixture of water and alcohol (usually 50/50), partly because the alcohol is combustible and will raise the octane level of the fuel. While water is not combustible, it has a greater capacity to cool the intake air temps down more than methanol alone. This effectively increases the octane rating of the fuel allowing performance gains to be obtained when used in conjunction with a supercharger or turbocharger, altered spark ignition timing, and increased boost levels.
Old 04-08-09, 11:33 AM
johnnyboy
johnnyboy's Avatar
did you google that yourself?
Old 04-08-09, 12:29 PM
javyLSU
2IS OG
javyLSU's Avatar
LOL, at least quote the source...
http://www.alcohol-injection.com/
Javier
Old 04-08-09, 12:53 PM
montgb
montgb's Avatar
Wow - CL cracks the whip hard on plagiarism! LOL.
Old 04-08-09, 02:13 PM
iSuxeL
iSuxeL's Avatar
That's where I quoted it from! LOL and why does it matter if I copied and paste? He asked I answered plain and simple geez
Old 04-08-09, 02:42 PM
javyLSU
2IS OG
javyLSU's Avatar
^Because you posted it like you wrote it, when you didn't. Common courtesy is to quote the source if you're going to use someone else's material - and technically it's the law. See the little "Copyright © 2009 DevilsOwn Injection" at the bottom of the web page? That means you can't redistribute their content (i.e. pass off as your own) without their express written consent.
Javier
Old 04-08-09, 03:14 PM
blk250
blk250's Avatar
+1...
Quick Reply: LMS SC with some methanol injection
