help! CEL, VSC, VSC OFF lights on! no acceleration...
Old 01-26-07, 03:01 PM
GQD_GS4
GQD_GS4's Avatar
Default help! CEL, VSC, VSC OFF lights on! no acceleration...
help guys!
something is wrong with my car... my CEL, VSC, and VSC OFF lights all turned on, and my gas pedal doesnt work unless i press it *all the way down.* am i in limp mode? i unplugged the 2 sensors next to the throttle body to try and get rid of the lights but it didnt work. then i disconnected the battery for 15 minutes to reset the ECU and that didnt work either.
i've been searching on CL and i think i need either a TPS or an accelerator position sensor. which one do i need and how much do each of these cost?
and can i buy these from carson or sewell (contact info?)?
thanks in advance guys
vince
Old 01-26-07, 04:50 PM
Spyder78
Spyder78's Avatar
you need to plug in the obd 2 scanner and see what codes you are throwing. Usually the vsc lights are associated with suspension components. Go to autozone and they can pull the code for you for free.
Old 01-26-07, 05:21 PM
w_star_001
w_star_001's Avatar
yeah go to Autozone and pull the code. the scanner will give u a little info about the code. keep us posted...
Old 01-26-07, 06:04 PM
LEXUS_KID
LEXUS_KID's Avatar
It also could be your (TPS) Throtle Position Sensor
Old 01-26-07, 06:52 PM
blackgs415
blackgs415's Avatar
Pull the codes.
I had the same prob.
Codes I got was P1120 and P1121
Looked up the the codes and it was the Accelerator Pedal Position Sensor
Bought the part 2206046010-LEVER ASSY, THROTTLE from Lexus
Installed it the same night it arrived.
No more problemo!
Old 01-26-07, 06:55 PM
blackgs415
blackgs415's Avatar
BTW: The information I found on this site was priceless. I am a new Lexus owner and it turns out the this is a common problem with the GS.
Old 01-26-07, 07:04 PM
DSM2GS400
DSM2GS400's Avatar
Had a similar problem today. Restarted the car and the problem went away. The night before I got a car wash and it was realy cold afterwards -17, I'm hoping that was part of the problem. Never happened before and I hope never again.
Old 01-26-07, 08:48 PM
GQD_GS4
GQD_GS4's Avatar
Originally Posted by blackgs415
Pull the codes.
No more problemo!
thanks for the input guys,
ok i went to autozone and i got one code: P1120. so i guess i'm in the same boat as blackgs415. how much does this Accelerator Pedal Position Sensor cost?
and BTW this also happend to me after i got my car washed! it wasnt that cold either, approximately 25 degrees out yesterday and 40 degrees today...
Old 01-26-07, 09:00 PM
GQD_GS4
GQD_GS4's Avatar
BTW whats what's carson lexus's contact info and who do i talk to there?
Old 01-27-07, 02:27 AM
GILLEXUS
GILLEXUS's Avatar
Found the part for $221 at Park place Lexus, Check Carason Toyota 1-800-908-6968 or 310-522-2300 and Try Sewell Lexus
http://www.trademotion.com/partlocat...&siteid=213808
Before I buy anything I would try re-setting the ECU who knows it may fix the problem?
Old 01-27-07, 05:45 AM
aliti19
aliti19's Avatar
I saw TPS & had a mental picture of Office Space. LOL
Old 01-27-07, 08:32 AM
@lpher
@lpher's Avatar
Pull the codes.
No more problemo!
Is it an easy DIY?
Old 01-27-07, 09:20 AM
w_star_001
w_star_001's Avatar
i also got the same lights on(CEL, VSC , VSC OFF) and the code i got is P0505( Idle control system malfunction). what parts do i need to replace? the thing is my car runs just fine.
Old 01-27-07, 04:11 PM
GQD_GS4
GQD_GS4's Avatar
Before I buy anything I would try re-seting the ECU who knows it may fix the problem?
thanks for going the extra mile for me! i said earlier though that i already tried resetting the ECU and it didnt work.
BTW so i started my car this morning and strangely enough all the check lights didnt show up this time and my car ran perfectly fine. i dont know whats up with my car, but i thinking i should get that part anyway to ensure that this doesnt happen again...
Old 01-27-07, 07:49 PM
GQD_GS4
GQD_GS4's Avatar
Default spoke too soon @#%@$
i guess i spoke too soon guys. so i was on my way out tonight and i turn on my car and bamm, on come all the CEL lights again...
arrgh
Quick Reply: help! CEL, VSC, VSC OFF lights on! no acceleration...
