help! CEL, VSC, VSC OFF lights on! no acceleration...
Old 01-27-07, 10:30 PM
Racerx0911
Racerx0911's Avatar
Originally Posted by aliti19
I saw TPS & had a mental picture of Office Space. LOL
LMFAO...juss watched that movie again!!!!!
Old 01-28-07, 10:36 AM
blackgs415
blackgs415's Avatar
its actually only four screws that hold the APP sensor to the throttle body. the only thing is that its in a tight spot. if you are pretty handy, its probably 2hrs of work.
Originally Posted by @lpher
Is it an easy DIY?
Old 01-31-07, 05:06 AM
ricco74
ricco74's Avatar
I was having the same problem just the other day. Does anyone have pics of the exact location of this TPS sensor?
Old 04-06-07, 04:23 PM
sleeper408
sleeper408's Avatar
Yes, does anybody have pictures of the TPS and APPS location?
So if I'm reading this right:
P1120 = Accelerator Pedal Position Sensor
P1121 = Throttle Position Sensor
Is this correct? And if I get both codes does it mean I should replace both?
Old 03-07-14, 01:58 PM
400DGRZ
400DGRZ's Avatar
Yes, instead of starting a new thread, I'm bumping this 7 year old thread.
Can anyone accurately answer the above question about the 2 different codes that sleeper408 previously inquired about?
I just pulled one code, P1121. Having same symptoms. CEL VSC VSC OFF limp mode and rough low idle.
Old 03-07-14, 03:04 PM
burny
burny's Avatar
You need to read these 32 pages to learn all about the 3 components on that throttle body. Get your self a multimeter and test the specs for each. Very easy and the specs are listed somewhere in this thread, I just can't remember where.
https://www.clublexus.com/forums/per...p-mode-32.html
mandyfig
06-20-22 04:29 PM
ratmstr808
05-31-18 12:03 PM
AllStrFame
02-26-17 04:54 AM
Emendoza
09-14-12 03:57 PM
varcity64
09-14-06 08:02 AM
Quick Reply: help! CEL, VSC, VSC OFF lights on! no acceleration...
