NA-T completed, coolant sensor not reading
I finally got my NA-T finished and am now boosting
my coolant temperature sensor is not giving a reading, i did the HG swap and might have not connected the sensor. Where is this sensor located?
oh yeah i have an S-AFC, and was planning on an AVC-R. Are there any wiring issues with running both, or do they work great together and wire in like a supra?
Will post pics later
-Derek
-Derek
Derek....congrats on your NA-t. The coolant sensor is located very near the oli filter. Between the coolant line and the oil filter. If I remember right it has a green colored socket on the side of the head. Good luck.
gadgetSC-t
gadgetSC-t
ok i found the sensor and it is plugged in, I did the HG swap with a 2mm, and while i had it off i took the head to the machine shop to get valve stem seals replaced. Could my sensor have been screwed up from the machine shop putting the head through a parts cleaner?
mjr955201
Performance & Maintenance
06-08-16 12:29 AM
DanielDD
12-04-14 03:55 PM
