Lexus SC400 fuel leak under engine
Okay so my SC400 is leaking underneath the car the vent right in front of the subframe is leaking fuel and cant figure out why. Just bought it from the owner of PSI who didnt take care of it
Any help or suggestions would be greatly appreciated
Most of the fuel lines are hard lines, which are unlikely to leak like that unless damaged or badly corroded. Up in the engine bay is where it's mostly soft lines, so you'll want to feel along those for moisture.
The fuel pressure regulator is my best guess at where the leak would be. If new copper crush washers weren't used when the PO did maintenance work, that could definitely do it.
Gliderman
06-07-07 09:40 PM
