Poly Exhaust Hangers
KARTBOY
http://www.kartboy.com/x4/
Torque Solutions
http://www.torquesolution.com/Exhaus...how=300&page=1
These are the brands I would recommend. I personally have KARTBOYs on my SC and my Integra.
When you install them on the car, ONLY USE SOAPY WATER. Do NOT use silcone spray or wd40. Those contain a chemical in the aerosol that can eat away at the poly and weaken it
Torque Solutions
I just saw a picture from Flyin' Miata this past week of what happens when a poly exhaust hanger comes in contact with the exhaust...
KARTBOY
Torque Solutions
Torque Solutions
Exhaust hanger diameters vary depending on what aftermarket exhaust you have. Length too. I have a big single exit exhaust on my car, and I bought hangers so that the exhaust would hang just below the rear subframe securely. This was over a decade ago, so I don't know what measurements I took. The best advice I have is if those numbers work for you, then buy those.
Doesn't that make them iffy in a car environment, especially below the car, where all sorts of cleaners and solvents are likely to be coming in contact? Maybe it's okay if it's just something in the aerosol, which isn't going to stick around long after use, but you'd still have to be careful cleaning/lubing nearby stuff down the road.
But if your car is constantly leaking oil, you probably should get that looked at first
Did you ever get poly exhaust hangers for your car? I'm looking for a way to mount the poly hangers without using the stock brackets since I don't have them. I traded exhaust with my friend and gave up my stock ones for these ghetto brackets he had made.
I've been trying to find some thick gauge L brackets and use 2 L brackets with a screw through the center to make hangers, but I haven't had any luck during my search. Maybe I should just try to find some use ones and cut them like this diy. http://forums.vwvortex.com/showthrea...xhaust-Hangers
calispyder
08-30-08 02:44 PM
octane103
Performance & Maintenance
12-28-04 07:13 PM
