1.5jzge just need a little info
Old 07-24-14, 11:43 PM
chillchewy
chillchewy's Avatar
Default 1.5jzge just need a little info
So I recently bought an 95 sc300 and ive been looking in too the 1.5jz ge and I know most of what I need. I wanna go with a t67 turbo and 272 hks cams. I know I need to get a 1jz harness and get it extended. Im going with gte pistons, rods. Im gonna go with a 1jz ecu. Is there anything else i need to get this working? Ive been searching alot about this im about 2 months in of research but I havent found a specific parts list
Old 07-25-14, 05:08 AM
vipsoarer
vipsoarer's Avatar
If you are going this route and using the GE and not the GTE block, you will need to drill and tap for the oil drain into the oil pan. You don't need the GTE pistons and rods as the GE ones are the same (as long as it isnt a vvti block). The rest is just following a 1jz swap list and switching out the block.
Tlaurin3
05-09-18 03:44 PM
socalturbo
SC- 1st Gen (1992-2000)
02-12-11 11:37 AM
Mrpickles
30
01-05-10 05:20 PM
phil2235nt
06-30-08 07:50 PM
FormosaSC
04-11-07 08:16 AM
Quick Reply: 1.5jzge just need a little info
