sc300 2jzgte help, grounded alt.
Old 07-14-14, 08:08 PM
Gussi123
Gussi123's Avatar
Default sc300 2jzgte help, grounded alt.
Hi guys, I need some major help so I had ever thing set up on my car!! Engine cranking and all, I noticed that the alternator was not charging, I took off the power cable on the alternator but I was distracted... so it hit the housing of the alternator... it still started for a while, but the next day (today) it won't crank and when I turn the headlights, the cluster turns off.... any advise?
Old 07-15-14, 06:31 AM
gerrb
Super Moderator
gerrb's Avatar
maybe drained battery judging from what you wrote above ?
Old 07-15-14, 10:59 AM
Gussi123
Gussi123's Avatar
That's the first thing i thought, I went and. Charged the battery (it was dead) I'm starting to think it's the starter because I figured out I had the dome light a Lil low (led lights on cluster) so when I turn the lights on, tthe cluster turns off, I'll keep updated, thx.
Old 07-15-14, 11:35 AM
soarer13oy
soarer13oy's Avatar
Check all your fuses especially the alternator fuse i believe its the 120amp one.
Old 07-17-14, 05:55 PM
Gussi123
Gussi123's Avatar
Well so far all fuses are good, but the starter still won't crank!!! Help plz? :/
Old 07-17-14, 06:37 PM
gerrb
Super Moderator
gerrb's Avatar
do you hear a click from the starter solenoid when you try to start it ? that is assuming you have a good battery and fuses are good ...
might be the solenoid that's why starter do not engage.
SerasLibre
08-21-17 12:34 PM
Ldavis01
09-20-16 09:56 AM
mildawg
02-26-15 03:13 AM
poplady
Maintenance
06-16-14 05:12 AM
Jmai22
GS - 1st Gen (1993-1997)
07-25-06 12:01 PM
Quick Reply: sc300 2jzgte help, grounded alt.
