sc400 Transmission swap
Old 03-13-14, 10:45 AM
JCHILL
JCHILL's Avatar
Default sc400 Transmission swap
I know that there is probably a thread on here about this already. Only problem is that I can't seem to find one. Every MT swap thread I look at for an sc400 ends up being a sc300 or v6 post.
What transmission will fit to my 97 sc400 v8 engine? I am sick of my automatic transmission and want to swap. Will a W58 work? And if so where can I find the adapter kit?
Old 03-13-14, 12:58 PM
ArkLaTexSC
ArkLaTexSC's Avatar
There's some scattered about. Check the build threads. AFAIK there's no established "kit", but rather a sort-of-established "method".
Old 03-13-14, 03:07 PM
oldManTan
oldManTan's Avatar
w58 is the most common cz it's from a SC300, or a Mark IV supra, later year models are better and tripod ones are the best/easier to fit. there are adapter plates and "kits" on 1uzfeswapkit.com, best deal is to find a wrecked sc300 and just take everything u can including the pedals and dash trim piece and shifter and ur golden besides some parts like the adpater plate, maybe bellhousing, and some bearings or something. i'm looking into doing the same thing and that's all i know so far. heard it takes about a day or two, and maybe even less with a lift. hope this helps a bit. r154 fit too, but not as easily.
Old 03-13-14, 09:45 PM
scENFORCER
scENFORCER's Avatar
Search 'sc400 manual', 'sc400 w58', or 'sc400 r154' or use '1uz' instead of 'sc400' and you'll get lots of search results. There's a lot of threads about this out there.
Old 03-14-14, 09:45 PM
kolessc400
kolessc400's Avatar
Check out 1uzswapkit.com also known as toyotav8.com. .. also driftmotion.com
Old 03-20-14, 11:48 AM
JCHILL
JCHILL's Avatar
Thanks I appreciate it.
Old 03-20-14, 09:56 PM
kolessc400
kolessc400's Avatar
Also check my thread out im in the middle of a swap now
https://www.clublexus.com/forums/bui...out-ready.html
kolessc400
Build Threads
65
03-22-16 04:16 PM
tenac2215
29
01-27-16 10:02 PM
gleich5
11-12-13 07:15 PM
shahbaz1
01-11-13 02:09 PM
sc101
05-02-11 09:03 PM
Quick Reply: sc400 Transmission swap
