ac/heat blower motor problem
#62
can't be because the plugs have a designated location and plug perfectly into each other, and one is female the other male. so if i plugged the male one into the relay the female one would just be hanging there doing nothing. it seems that relay is for 95+ SCs because all the ones on ebay are from 95+ SCs as well.
#65
Anyone got any other ideas? Also I'm pretty sure i confirmed that the big relay part is for 95+ only. I was on ls forums and they were saying the same thing that 95+ started using the expensive relay instead of the little 2 wire box that we have. I'm gonna invest in a multimeter and just go at the wires with it, need to find if I'm even getting power to the whole system and then trace the power wire to where it's going because it disappears behind the dash into the firewall.
#66
Well, if only '95+ that uses that relay and replacing that relay solved an apparently identical problem, I would begin by looking at the corresponding "little 2 wire box" on '92-94s to see if it's similarly dysfunctional. Assuming you haven't already tried replacing and/or testing it.
#67
#68
