New Timing belt, water pump, radiator. OVERHEATING?
Old 11-21-13, 12:32 PM
Studiogeek
Studiogeek's Avatar
Default New Timing belt, water pump, radiator. OVERHEATING?
Hi,
I just got a new timing belt kit, water pump, radiator installed. The car never overheated but it is now. Just checked thermostat and it was open. Mechanic said he bled it well. Any ideas what it could be?
It is a 1UZ.
SG
Old 11-21-13, 12:39 PM
eknine9
eknine9's Avatar
Try burping the system anyway.
Mech. might not have bled it as well as he said.
Can you hear any burbling/bubbling when the car is running?
Old 11-21-13, 01:09 PM
BiGEZ
BiGEZ's Avatar
As mentioned above it could be air still trapped in the cooling system. Try bleeding it again. Is your hydro fan setup working as it should?
Old 11-21-13, 02:41 PM
Studiogeek
Studiogeek's Avatar
Thank You.
YES!
Crazy burbling, gurgling sound through the upper hose when detached from the radiator.
Does that mean air in system?
Fan seems cool.
Old 11-21-13, 04:06 PM
OG Dada
OG Dada's Avatar
If the thermostat is working fine it might be air in the coolant system. The fill-up bolt of the coolant is at the top of the thermostat neck. Make sure he refills the coolant from there not just the coolant reservoir, you won't have that problem.
*tiny red circle LOL
Attached Thumbnails New Timing belt, water pump, radiator. OVERHEATING?-cbde28f5-79b0-47df-ae9b-5d18ff61f486-1244-0000007324e2f226.jpg
Old 11-21-13, 04:42 PM
turbodremz
turbodremz's Avatar
Make sure when your purging the system, to run your heater!! This is commonly looked over.
Old 11-21-13, 05:07 PM
eknine9
eknine9's Avatar
Originally Posted by Studiogeek
Thank You.
YES!
Fan seems cool.
Yes, most likely air in the system, also pay attention to what turbodremz said as well, you definitely want to run the heater when you do it.
Old 11-21-13, 05:46 PM
Studiogeek
Studiogeek's Avatar
Major thanks!
Willdo!
SG
Old 11-21-13, 08:11 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
An old trick is to pour some coolant into the resevoir and fill it to the top. The container should have an air bleeding hole and as the coolant is circulated through the engine, the air is "burped" out into the resovoir. It is likely air in the system.
*Of course you fill the radiator coolant directly into the rad as well.
Old 11-22-13, 04:25 AM
Studiogeek
Studiogeek's Avatar
Thumbs up
Thanks KP!
When I arrived, he had a funnel/bottle in that exact hole filling it with red.
This may have been overlooked. Ill ask him when I return today.
Thank You.
Wildoo! Thank You!
Awesome, if it's not already sorted, we will try this.
Thank You!
Old 11-23-13, 07:56 AM
Studiogeek
Studiogeek's Avatar
Ha......
The new water pump broke immediately after installation. It was an Aisin (or something like that).
The plastic disk that spins was broken in half when he pulled it back out. I just will have to take the loss as I have been sitting on this timing belt kit since last year. Should have done it right away.
Old 11-24-13, 03:15 PM
BiGEZ
BiGEZ's Avatar
Aisin is usually the OEM brand which also has Toyota stamped on it. Wow brand new oem part failed. Glad you got if figured out before it ruined your motor.
ellie12mae
02-20-18 07:10 PM
Phoebster
10-17-17 09:01 PM
Pos300
06-10-15 06:35 AM
chestman88
SC- 1st Gen (1992-2000)
09-08-11 07:49 PM
RedSC
GS - 1st Gen (1993-1997)
05-24-10 10:50 AM
Quick Reply: New Timing belt, water pump, radiator. OVERHEATING?
