Door Bind
Old 10-29-13, 03:56 AM
tlshroeger
3rd Gear
tlshroeger's Avatar
Default Door Bind
Answer found
Old 11-04-13, 01:18 PM
SC3coupe
SC3coupe's Avatar
Originally Posted by tlshroeger
I have a '94 SC400. The drivers side door is binding against the front fender when opened. It's getting to the point that the door is very difficult to open. I'm new to this car and not familiar with the door hinge. I'm seeing some looseness around the pin but not sure how to tighten. If anyone has experienced this problem please let me know where to start and the cure you used. Better yet, if anyone can direct me to an exploded view of the hinge, I can take it from there.
Thanks, Tom
Hi, you posted in the wrong section.
Your door hinge is worn out, it is not serviceable.. you need a better condition one or a new one.
You could try this first, but it doesn't really address the issue properly or may not help at all. The hinge will need to eventually need to be replaced. You can really take the paint off or in worse case pinch and dent the fender.
https://www.clublexus.com/forums/sc-...7-seconds.html
Bretth
03-09-17 01:43 PM
Tymboo
30
02-23-16 01:21 PM
kez
SC- 1st Gen (1992-2000)
07-23-09 01:50 PM
rykwebb
05-28-08 07:27 PM
97SC
12-19-03 02:24 PM
Quick Reply: Door Bind
