Passenger door won't open from inside or outside
In Recovery Mode
Sounds to me like you might have broken the handle "arm" that goes from the exterior handle, down to the latch assembly, inside the door. If that was the case, then you might need an exterior handle latch clip that holds the arm in place. A $5.88 part at most Lexus dealerships.
I'd just break the window if I was in your situation. clean up as much of the glass as possible and shine a nice light down where the window was, jimmy the bar to open the door then take the inside panel off, clean the rest of the glass, fix the handle assembly(s)... get another window and install it then look for something else to mess with..
or...
I'd also cut a big hole in the door but then i'd have to fix the hole or just get another door. and know forever I don't have an original door, or an original door with a patched hole in it... if this was a ford who cares but it's an SC so this leads me back to the glass plan.
you're selling it anyways right? why not spend a few bucks on a window to have a operating door and increase the chance of it selling? nobody wants a 1 door coupe.
or...
In Recovery Mode
This is the best suggestion, it might be possible without damaging the door or the panel. A little glue will fix the panel pieces.
http://www.planetlexus.com/lexus-for...p/t-16200.html
And, it sounds like your bar probably did break. Don't run to the dealer to get that stuff, over 400 bucks for the entire assembly. Go to the pull yard and get one.
Hope you get in!
Also, keep working the handle. Sometimes, if the connection is just loose, all you need is movement then you can...just...open..the..door!
Hope you get in!
Welcome aboard.
hey now. I was just saying what I would have done in that situation. i'd rather replace a window than a original door panel/door. still might be able to remove everything you can off the door panel like the speakers and door handles and gain access to the handle rods and open the door and save both the door and window. dunno how much you can access without the door open so i didn't mention it. I had this happen in a friends camaro excpet the locks didn't work either so Ididn't have much choice. fixed both handles and replaced window next day no biggie. =)
