99 sc300 loss of power.. help ?
hey guys.. i have a stock 99 sc300 and until recently it started to lose power as i drove it. ngk spark plug and wires were all replaced within the past year. it would just bogg pretty bad here and there.. especially when i start to accelerate from a stop, it would bogg really hard and then take off only to do more bogging. Anyone familiar with this ?.. i would really appreciate it
Awaiting the wrath of OLT in 3...2...1....
( https://www.clublexus.com/forums/sc-...read-this.html )
More on topic - any codes being thrown? Have you checked your fuel pump ecu, checked your MAF, changed your fuel filter, and changed your fuel pressure regulator?
OP - I'm a little bit confused (or just reading way too in depth) but when you say that the plug wires were replaced, do you mean all of the coil-packs over the plugs were replaced?
On the other hand, it should be throwing some sort of code...I'm with these guys above though, it could be any number of issues... Did your search of the forum make any issues stand out at all?
Do you see a lot of oil spitting on the outside of the covers?
