2jzge obd1 code 14 please help
Old 05-18-13, 10:44 AM
soarer479
soarer479's Avatar
Default 2jzge obd1 code 14 please help
Having some trouble with my 94 gs 300 , its all stock throwing code 14 which is igniter signal circuit malfunction. If the car is cold and the ecu has been reset it will crank and run ok until it gets warm throws code 14 and cuts off then will not crank back up . Because I have them laying around I've swapped in a known working igniter , ecu, and coil pack with no success. Any other suggestions ?
Old 05-20-13, 12:49 AM
soarer13oy
soarer13oy's Avatar
Check for continuity from ignitor wire to ecu with a volt meter
topgun129
07-08-14 05:20 AM
BigRon239
03-19-13 11:59 AM
ScDre
07-09-12 02:47 PM
Derf
11-10-04 11:35 AM
Quick Reply: 2jzge obd1 code 14 please help
