Aftermarket ECU to replace master key in 98-03
Old 04-03-13, 02:23 PM
hyjaxx
hyjaxx's Avatar
Default Aftermarket ECU to replace master key in 98-03
If you lose the master key to a 98-03 Lex the dealer tells you that you have to get a new ECU. Engine immobilizer code.
Now, is there any way around this? If I toss my old Motec M8 in my '99 and just have a new key cut will that work? I wasn't planning on using that but I don't want to give the stealership one red cent, especially when they charge Aftermarket ECU prices for a stock ecu...and then key fees.
Mods: Move this is you want but I put it here deliberately.
Old 01-27-14, 04:45 PM
Mkt
Mkt's Avatar
I'm having the same problem did you find another one or did you have yours "re flashed" if so who did it and have you had any problems thanks
jehmin
11-07-23 12:12 AM
63Galaxie
10-27-16 02:50 PM
Dadikins
RX - 1st Gen (1999-2003)
11-16-10 07:05 AM
olddog
03-01-07 09:35 AM
SHEEP5
07-12-06 12:51 PM
Quick Reply: Aftermarket ECU to replace master key in 98-03
